Your Portal Version: 1.0.6
Boardlink: http://dragondebronce.com
Hello, i have problem, i make changes in a block, in tempolate,
Im try with clean cache, and refresh template, and theme
When i do refresh tempate, i wait for 2 minutes, and the screen going to black, i cannot refresh the templeate from acp panel, whats is wrong? i need to reinstall the portal? i make a changes to any block, please tellme what to need to do! to fix this, thanks
cannot refresh template
bfharreguy
Re: cannot refresh template
I don't think this is a portal issue, since Board3 Portal is not responsible for refreshing the template. Did you try to enable debug in your config.php?
bfharreguy
ok, probably you have right, but how can i see the bugs? with debug? How? Thanks
Hello bfharreguy,bfharreguy wrote: Boardlink: http://dragondebronce.com
Currently I do not see the copyright of the Board3Portal and phpBB on your side.
From me you get so no support.
