Your Portal Version: 1.0.4
Boardlink: http://www.gwmara.com
Nothing
Nothing
Is there a way to choose what blocks on the portal, both default and added blocks, to make viewable to guests (Only members are suppose to se all of them)
Custom blocks only for members
Re: Custom blocks only for members
Found this in the german support thred, maybe you can use that.
viewtopic.php?f=31&t=1829&start=15#p12290
Use google translate if you arent strong in german![Lächeln :)](./images/smilies/icon_e_smile.gif)
Thank you, but I can't use that. I'm a newbie to php and if Google translate something wrong, I will never find it or I'll put the code in the wrong place.
Before I make a post on any forum, I do spend a lot of time searching for it, trying to avoid duplicated questions. I do have a lot of questions and a lot of them show up on this board in german. This being a german board it's understandable.
Eksample
![Frage :?:](./images/smilies/icon_question.gif)
Eksample
Rumprobieren The HTML code may times if things do not work better:
