Your Portal Version: 1.0.4
Boardlink: http://www.mrchat.org
Installed the portal
Edit the css, but seems that the style's one it's over the portal's one
Hi, i dunno how to get the board3 portal css working with my own theeme
CSS conflict
Re: CSS conflict
Make sure you uploaded all files. As your style is based on prosilver, you also have to upload the prosilver portal files to your style.
I can't find portal.css in your style's theme folder.
Re: CSS conflict
well thank you, now works better but it's still not ok, as you can see the blue font on a blu background doesn't look fine, the Menu block doesn't look like here and the latest news block is too small... i think all the files have been uploaded than shouldn't be my fault
Re: CSS conflict
Refresh your theme cache. If you don't like the blue text on the blue background, then you might want to ask the author of your style as he made it that way.
Re: CSS conflict
I refreshed the cache and now looks really fine... can i fix the latest news problem?
Re: CSS conflict
Open your ACP and browse to the Portal Configuration.
Click on "News" in the sidebar and change "Display the number of replies and views" to No.
