Help with ACP
Onarous
Help with ACP
Post by Onarous »
Boardlink: http://www.wowlofa.co.uk
PHP Version: 5
I've got a one click install from heartinternet running on my website. this is phpbb 3.0.4 with board 3 1.0.4.
I've added a few mods to the forums, and locked it down for members to see almost all of it. with a theme from www.pbwow.com
I've loaded the module manually as well as the auto install. Yet I have no access to change settings on the portal. This has only been since this was installed as I uploaded a phpbb3 calendar mod that was accessed via the ACM and the permissions on that worked fine.
I've tryed purging the cache several times yet nothing will make this "portal" tab show on the ACP.
I've search through this site and others, yet anything posted doesn't seem to change the problem I have.
Any help would be welcome to this.
Portal added, install worked fine, no access to the options for admining the portal via the ACP.
Permissions on me are full admin /founder checked permissions and they are showing green for me to make changes to the portal, yet no tab to be able.
This is not the only mod I've no access to it's tabs, Also a raid progression mod. I was hoping they are both same fix
Thanks
Khamosh-Saya
phpBB.de User: Khamosh-Saya
phpBB.com User: Khamosh-Saya
Re: Help with ACP
Post by Khamosh-Saya »
viewtopic.php?f=10&t=2952
Read This Topic
Before what u do Take Backup
