Boardlink: http://www.nova-nilla.com/Members/phpBB3
PHP Version: 5.2.6
MySQL Version: 5.0.27
Updated Board3 Portal from 1.0.2 to 1.0.4
Inspected all file edits - they seem fine. Attempted to disable certain blocks to see if there was a conflict. Tried to uninstall new updates and restore backup, which served only to lock me out of my system after the update timed out (several times). Used System Toolkit to get back in. Backup seems semi-complete. Some small inconsistencies in the board, but I don't know if there's anything major that has gone wrong.
Updated from 1.0.2 to 1.0.4 and received this error when I went to the Portal:
Fatal error: Call to undefined function format_birthday() in /u/vp/nova-nilla.com/www/Members/phpBB3/portal/block/birthday_list.php on line 68So then I started looking around the rest of the site. The Gallery page wouldn't open. Instead, I got this error when trying to open the gallery (version 1.0.3):
Fatal error: Cannot redeclare class bbcode_firstpass in /u/vp/nova-nilla.com/www/Members/phpBB3/includes/message_parser.php on line 1026I re-checked all the file edits. The only edit I did not perform in the two-step update from 1.0.2 to 1.0.4 was in the overall_header.html file, replacing this line: <!-- IF not $S_IN_PORTAL or not S_DISPLAY_MAINMENU --> That line simply was not in my header file, and I assumed I had taken it out to avoid losing my navbar with tabs when I navigated from the portal to other places on the site. Still, I couldn't see why that would be critical, but maybe somebody else can help?
I finally decided to restore my backup and replace my five edited directories with the originals, and my restore timed out on me several times, and I got locked out of the system. Got back in with system toolkit, enabled the board again, opened it up and apparently the restore SEEMS to have worked. I only worry that it was incomplete before locking me out. I don't know.
Any help on what caused this huge issue? I really want my board updated so I can view recent/random images in my portal and index.
Thanks[/i]
