Your Portal Version: 1.0.2
Boardlink: http://www.crustygamers.com
PHP Version: 3.04
no problems
no problems
just a question, on the welcome block and the custom center block, how large of a pic can I put in those blocks before it breaks the layout?
Image size, how large can I go?
Re: Image size, how large can I go?
Nobody can tell you a general size. It depends on your style, the screen resolution of the user, your width of the side columns, etc.
You have to try it yourself.
fair enough, thanks kevin
if you have images that bloating your style you can use the AIR BOX IMAGE RESIZER MOD. Here a link: http://www.provisum-illumina.com/en/inf ... phpbb.html
There are several of those mods outside that resizes images for your need. I use the mentioned above and it works perfect - and you can configure it as well by editing a file...
------ @ the mods -------
I hope this is not seen as falsely advertising or promoting - just want to point out that there are image resizer mods out for phpBB3
Huor, why should we see it as advertising? It's phpBB stuff, so everything is fine. You are not promoting links to electric blankets.Huor wrote:------ @ the mods -------
