"MCP info on index" MOD into the Portal
DutchToxophilite
phpBB.com User: DutchToxophilite
Post by DutchToxophilite »
Your Portal Version: 1.0.2
Boardlink: http://www.handboogforum.nl
Nothing, question. No issue.
Searching trough this board, and trough phpbb.com
I have installed the "MCP info on index" MOD.
And me and the Moderators really quiet heavily on it. The reason for this is, that I enabled the "block first posts" feature. To be sure no spammers can spam my board.
But as a result of the NEWS showing the latest posts on the portal, we now tend to forget to go to the board index frequently, thus missing these warnings.
I now want to incorporate the "MCP info on index" MOD into the portal, but my php writing skills are poorly, so I have not a sure clue where to start.
Please advise/help.
thanx.
grtz,
Twan
The joy's of Archery can be found anywhere. Far places only offer exotic ways to suffer.
Re: Can the "MCP info on index" MOD be incorp. into the Portal?
Original Mod MCP info on index by Derky
Open portal.php
search:
// output page
add before:
// Show amount of reported and queue posts for authenticated users
if ($auth->acl_getf_global('m_report') || $auth->acl_getf_global('m_approve'))
    if (!function_exists('get_forum_list'))
        include($phpbb_root_path . 'includes/functions_admin.' . $phpEx);
    $user->add_lang('mcp');
    // Reported posts
    $forum_list = get_forum_list('m_report');
    if (!empty($forum_list))
        $sql = 'SELECT COUNT(r.report_id) AS total
            FROM ' . REPORTS_TABLE . ' r, ' . POSTS_TABLE . ' p
            WHERE r.post_id = p.post_id
                AND r.report_closed = 0
                AND ' . $db->sql_in_set('forum_id', $forum_list);
        $result = $db->sql_query($sql);
        $total = (int) $db->sql_fetchfield('total');
        $db->sql_freeresult($result);
        if ($total)
            $template->assign_vars(array(
                'L_REPORTS_TOTAL'    => ($total == 1) ? $user->lang['REPORT_TOTAL'] : sprintf($user->lang['REPORTS_TOTAL'], $total),
                'U_MCP_REPORTS'        => append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=reports'),
                'S_HAS_REPORTS'        => true)
    // Posts in queue
    $forum_list = get_forum_list('m_approve');
        $sql = 'SELECT COUNT(post_id) AS total
            FROM ' . POSTS_TABLE . '
            WHERE ' . $db->sql_in_set('forum_id', $forum_list) . '
                AND post_approved = 0';
        if ($total)
                'L_UNAPPROVED_TOTAL'        => ($total == 1) ? $user->lang['UNAPPROVED_POST_TOTAL'] : sprintf($user->lang['UNAPPROVED_POSTS_TOTAL'], $total),
                'U_MCP_QUEUE'            => append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=queue'),
                'S_HAS_UNAPPROVED_POSTS'    => true)
prosilver
open root/styles/prosilver/template/portal/portal_body.html
search:
<!-- INCLUDE overall_header.html -->
add after:
<!-- IF S_HAS_REPORTS or S_HAS_UNAPPROVED_POSTS -->
<div id="message" class="rules">
    <div class="inner"><span class="corners-top"><span></span></span>
        <strong>{L_INFORMATION}:</strong>
        <!-- IF S_HAS_REPORTS --><a href="{U_MCP_REPORTS}">{L_REPORTS_TOTAL}</a><!-- ENDIF -->
        <!-- IF S_HAS_REPORTS and S_HAS_UNAPPROVED_POSTS --> &bull; <!-- ENDIF -->
        <!-- IF S_HAS_UNAPPROVED_POSTS --><a href="{U_MCP_QUEUE}">{L_UNAPPROVED_TOTAL}</a><!-- ENDIF -->
    <span class="corners-bottom"><span></span></span></div>
<!-- ENDIF -->
subsilver2
open root/styles/subsilver2/template/portal/portal_body.html
search:
add after:
<div class="forumrules">
    <h3>{L_INFORMATION}</h3><br />
<br clear="all" />
<!-- ENDIF -->
Edited topic title and moved to "Released Blocks"
DutchToxophilite
Re: "MCP info on index" MOD into the Portal
Hi Kevin.
Your Nicks at phpbb.com and phpbb.de are more realistic.
YOU are a true SAINT (and that coming from an atheist!!) ;)
grtz,
Twan
DutchToxophilite
Worked like a charm.
One small remark......
The text to search for contains some blankspaces before and after the "to search" text. Which prefends them to be found automaticcaly.....
Just a small tip for the other users who want to install this.
grtz,
Twan
Thanks, corrected.
JeRicHoOL
Post by JeRicHoOL »
Wo kann ich die Modifikation downloaden? Der Link hier funktioniert nicht.
Würde nämlich auch gerne so einen Block haben mit den MCP Infos im Portal.
DutchToxophilite
Hi JeRicHoOL
I can read German, but my writing is terrible, so I will keep it in English.
This is one of the official released MODs from phpbb.com
When the site will be up and running again I will post a link to it. (If I don't forget)
grtz,
Twan
Kevin wrote:Original Mod MCP info on index by Derky
Und ich kann Englisch lesen aber nicht gut schreiben. :lol:
Selbst wenn es vergessen solltest, der Link hat Kevin bereits genannt. :D
Sobald phpBB.com wieder Online ist kannst es dir dort runterladen.
Alternative suche mal auf phpBB.de oder bei Google vllt. gibts auch eine Alternativ-Download :roll:
Gruß Chris
Äh, Moment:
JeRicHoOL wrote:Wo kann ich die Modifikation downloaden? Der Link hier funktioniert nicht.
Da brauchst du nix runter laden, den Code für das Portal habe ich oben gepostet. :?
JeRicHoOL
Post by JeRicHoOL »
I did the changes above and nothing on my portal changed. There is no new block. :? Is there a mod I need to install for that block?
JeRicHoOL wrote:I did the changes above and nothing on my portal changed. There is no new block. :?
Already purged your board cache?
And please note: the block will only appear, if at least on post is reported for the admins / moderators. To test it, just report a post. ;)
JeRicHoOL
Post by JeRicHoOL »
Ok I have done this and then I got some kind of information line.
http://i107.photobucket.com/albums/m287 ... 030009.gif
Is it correctly how it is?
DutchToxophilite
That's would it would look like (I guess, as I see it in ProSilver). But the bar gives the same information.
grtz,
Twan
