When I check all those board3 examples, including this oficially site, all fits perfectly to my 1024x768 screen resolution, however my own portal somehow don't work and it's so wide from left to right (huge center, with proper sized left and right blocks) that It don't fit to my screen (half right block is hidden), unless I check it on other 1280 x 800 pixels resolution PC (then it's ok)
First I though that this is matter of my chosen Redsilver style, however I sucessfully upgraded board to newest version and started to use new AeroBlue style - with same problem. I have no idea why center is so big. It's most likely my mistake and I overlooked something, however no matter how much I check in hope to find out what's wrong, I can't find a solution.
Any help would be appreciated.
My board3 don't fits to my 1024x768 screen resolution
Re: My board3 don't fits to my 1024x768 screen resolution
A link to your board would be helpful.
Hmm.., yes of course.
When I opened thread, I actually entered all required infos, including link to my board. Maybe my wrong "Save" instead "Submit" button push and then "no" to "save draft" deleted my informational entries. (I have no idea what phpBB3 developers was thinking when they placed new "save" button on position which is so easily confused with "Submit"..)
Ok, ok.. sorry, it's my fault anyway, so let me try again:
Do you have MODs (Modifications) installed at your forum or Portal: no
What have you done before the problem was there: not much, it's new installation
What have you already tryed to solve the problem: styles change
Boardlink: [removed by author 1.1.2009]
It fits perfectly to 1280 x 800 pixels resolution, but many people, including me, still use 1024 x 768 pix. resolution. Beside that each other board3 portal looks as it should in 1024 x 768, so I believe that it's my fault, but can't find mistake.
Thank you for your time and patience.
I saw already complains here around about lack of board3 support, but I didn't know that it's so bad. It looks like nice portal and I would gladly use it but because lack of preparation to waste time for basic/small support am afraid that I will be forced to migrate to other portal platform.
Admin, please delete my portal account. Thanks and happy New Year.
Happy new year to you too! Account deleted as wished.
Have fun with another portal.
