Portal as Site Main Page
kiokus
Post by kiokus »
Kevin wrote: add to your .htaccess this:
This code is correct if the Portal is at the root.
But if the Portal is in a Directory, named par example, "forum"?
Then the code perhaps would be with "forum":
DirectoryIndex forum/app.php/portal index.php index.html index.htm
But in this case, this will show only the Portal modules text, broken without styles. With an URL like "www.site/app.php/portal", and not "www.site/forum/app.php/portal".
What is wrong?
Thanks in advance.
Re: Portal as Site Main Page
The portal extension is always in the same directory. The code must be like this:
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Post by Harewood »
Just to confirm, if I want the Portal page to be the main homepage I do the following:
  • ftp to forum root dir [where app.php resides]
  • download .htaccess file
  • open .htaccess with TextPad and add at the following text to the bottom of the file
# The following code makes the portal page the default homepage.
  • save .htaccess file and ftp upload updated .htaccess file to forum root dir.
Jason
kiokus
Post by kiokus »
Kirk wrote: 19. August 2020 20:01 The portal extension is always in the same directory. The code must be like this:
As we have already mentioned, this code is correct only if the Portal and the Forum are at the root.
But it doesn't work if they are in a Directory.
The question is what is the correct code if they (Forum and Portal) are in a directory, and not in the root?
Thanks in advance.
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Post by Harewood »
Just tried the following code in .htaccess and it didnt work...
There is an alternative, create a file called portal.php with the following content:
header("Location: https://xxxx/app.php/portal/");
exit;
Replace the xxx with the URL to your forum. Load this file into your forum root (where the config.php is located).
Open: root/.htaccess
Insert this at the very end:
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Post by Harewood »
Hi Kirk,
Thank you for the reply and I did as requested but got the error Page not found?
Does it work like that?
header("Location: https://xxxx/app.php/portal");
exit;
Or:
header("Location: https://xxxx/portal");
exit;
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Post by Harewood »
Thank you, will give it a go tomorrow... ;)
