Default Settings For Latest News
HoodieWeather
Post by HoodieWeather »
Your Portal Version: 2.1.0
Just would like to know the default settings for this box thanks
sgtevmckay
phpBB.com User: sgtevmckay
Re: Default Settings For Latest News
Post by sgtevmckay »
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
"reset module configuration" <--- using that will set the module back to default settings for you.
sgtevmckay
Talonos is correct,
I was tired and forgot to place a red box around the "Reset module configuration" and "checkbox".
What you see in the image should also be the default settings, I activated several months ago and walked away ;)
