[RELEASE]mChat V2.1.0 Board3 extension
johnvsd
Re: [RELEASE]mChat V2.1.0 Board3 extension
Post by johnvsd »
I did exactly what the instruction said. Mchat is running on my site but can't find it when adding it to the portal block since there is no mchat related file installed into portal module. If you view the attached picture, you will understand what i am trying to get help
You need the mchat extension and also the mChat on Board3 portal extension.
Are both extensions installed?
johnvsd
Post by johnvsd »
I only download the Mchat extension from this board. If you could walk me thru this confusion i really appreciated your time and your effort. Thanks again
You can find all the necessary information in the first post under Installation
witvisser
Post by witvisser »
When updating the extension "Collapsible Forum Categories" to the latest 2.0.0 version, i don't see the - and the + signs anymore on the Chat?
My forum is 3.3.2.
It is probably due to the mChat extension and not the portal module.
witvisser
Post by witvisser »
Thank you @kirk ;)
Found the solution here.
JeyP91
phpBB.de User: JeyP91
Post by JeyP91 »
unfortunately the download link is not working anymore and the git repo here does not have the latest changes as well.
Could someone please provide a download link or @talonos could you update the git repo?
That would be amazing!
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
JeyP91 wrote: 30. May 2021 14:53 Hi,
i've not worked on mchat for quite a while but my most recent one is HERE
JeyP91
Post by JeyP91 »
talonos wrote: 19. June 2021 16:47 i've not worked on mchat for quite a while but my most recent one is HERE
Hi talonos,
thanks for uploading, but this is the outdated version 2.0.2, which is not supporting mChat 2.1.0.
There was an update of the extension to support mChat 2.1.0. That's the version I need. Do you by any chance have it?
Thanks again!
talonos
Portal Specialist
Post by talonos »
JeyP91 wrote: 20. June 2021 13:17
Hi talonos,
Thanks again!
looking at my backup it looks like i may have lost that update.
JeyP91
Post by JeyP91 »
talonos wrote: 21. June 2021 15:10 looking at my backup it looks like i may have lost that update.
That's unfortunate. Thanks nevertheless!
If someone else has it lying around anywhere, I would be very happy if you could provide it. Thanks!
Neves
phpBB.com User: Neves Projects
Post by Neves »
Has anyone got MChat to work in Portal on php 3.3 ? if so can you share how.
the download for mchat extension in 1st post hasn't been working
John
Post by John »
Neves wrote: 13. November 2021 16:15 Has anyone got MChat to work in Portal on php 3.3 ? if so can you share how.
Bump :mrgreen:
Edit: Found it here https://reyno41.bplaced.net/phpbb/viewt ... 2370#p2370
Return to “v2.1.x”
