[RELEASE]mChat V2.1.0 Board3 extension
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Extension Name: mChat on Board3 portal Extension
Author: Talonos
credits: dmzx,RMcGirr83 and kasimi for making this extension possible.
Extension Description:
This extension will allow you to have mChat displayed on your board3 portal (requires mChat 2.1.0+ installed)
block can be used in Top/Center/Bottom only
IF UPGRADING "mChat" DISABLE "mChat Board3" extension BEFORE DOING SO or you can get locked out of ACP
below setting in mChat configuration IS REQUIRED to have mChat display on board3 portal
Display mChat on the index page: Yes
Extension Version: 2.1.0+
Download:
http://s000.tinyupload.com/index.php?fi ... 6603266868
Installation:
1. Download the latest release.
2. Unzip the downloaded release, and change the name of the folder to `mchat`.
3. In the `ext` directory of your phpBB board, create a new directory named `dmzx` (if it does not already exist).
4. Copy the `mchat` folder to `/ext/talonos/` if done correctly, you'll have the main extension class at (your forum root)/ext/talonos/b3pmchat/composer.json
5. Navigate in the ACP to `Customise -> Manage extensions`
6. Look for `mChat Board3` under the Disabled Extensions list, and click its `Enable` link.
7. add the module to your portal via the menu at ACP -> Extensions -> Portal -> Portal Modules -> add modules -> 'mChat on Board3 Portal' (top/center or bottom modules only)
this extension requires mChat 2.1.0+ available from https://www.phpbb.com/customise/db/extension/mchat_extension/ please update to 2.1.0+
original authors forum for mChat:
http://www.dmzx-web.net/viewforum.php?f=53
Revision information:
2.1.0
code updated to work with mChat 2.1.0+
fixed a bug where it wasn't pulling the correct "mchat height" setting onto portal
2.0.2
code updated to work with mChat 2.0.2
2.0.0
code updated to work with OFFICIAL RELEASE. no more RC versions :)
2.0.0-RC6
Collapse on portal now works (collapse on index will also collapse on portal)
due to major code changes i've had to use a version check for mchat RC6 so that boards don't get broken by addon.
any addons that work in mchat will also work on b3pmChat
2.0.0-RC5
fixed an issue with collaspable categories on index. still no collapse on portal.
1.0.0.RC3
updated to newest release of mChat.
added ext.php to check that mchat is enabled before this EXT is allowed to be enabled (if this first before mchat it breaks board)
1.0.0.RC2
no more mChat core edits required now as this is a seperate extension. requires mChat to be installed FIRST
1.0.0.RC1_board3
initial RC release
will work on any page where the full portal works.
cptgrato
Re: mChat_1.0.0-RC2 Board3 extension
Post by cptgrato »
Guten Morgen, ...
ich habe leider einen Fehler bei der aktualisierung gemacht .
Alter Stand :
- 1.0.0RC1 (deaktiviert)
- mChat_1.0.0-RC1 Board3 extension (deaktiviert)
Ich habe mChat_1.0.0-RC2 Board3 extension aufgespielt und dann aktiviert.
Ich habe leider den Schritt mChat 1.0.0RC1 auf mChat 1.0.0RC2 vorher zu aktualisieren ausser acht gelassen
Nun komm ich weder aufs Forum noch in den Admin Bereich.
Versucht habe ich die Ordner
b3pmchat und mchat umzubenennen, so dass er sie nicht findet, in der Hoffnung wieder in den Adminbereich zu kommen / ohne Erfolg.
Was kann ich tun um wieder in den Admin bereich zu kommen ?
Kann ich die extension in der Datenbank deaktivieren um wieder zugriff zu erlangen ?
Nachtrag, ...hab es hinbekommen.
1. in der Datenbank das modul deaktiviert ( auf null gestzt )
2. cache manuell auf dem server geleert
danach hatte ich wieder vollen zugriff
talonos
Portal Specialist
Post by talonos »
yes this is an issue that i was informed about and will be fixed for RC3 release this weekend.
talonos
Portal Specialist
Re: [RELEASE]mChat V2.0.0-RC3 Board3 extension
Post by talonos »
1.0.0.RC3
talonos
Portal Specialist
Re: [RELEASE]mChat V2.0.0-RC5 Board3 extension
Post by talonos »
2.0.0-RC5
talonos
Portal Specialist
Re: [RELEASE]mChat V2.0.0-RC6 Board3 extension
Post by talonos »
2.0.0-RC6
remkot
phpBB.de User: remkot
phpBB.com User: remkot
Post by remkot »
Thanks for this!! :D
talonos
Portal Specialist
Re: [RELEASE]mChat V2.0.0 Board3 extension
Post by talonos »
2.0.0
ALXGS
phpBB.com User: ALXGS
Post by ALXGS »
This extension works with new version of phpbb? (3.2) ?
talonos
Portal Specialist
Post by talonos »
ALXGS wrote: 2. February 2017 17:16 This extension works with new version of phpbb? (3.2) ?
if mchat is working on index then yes this will work on portal.
ALXGS
Post by ALXGS »
Thanks man!
Contergantreff
phpBB.de User: Contergantreff
phpBB.com User: Contergantreff
Post by Contergantreff »
Hat jemand eine Idee, wie man den Chat auf der Forumsseite los wird?
Ich möchte den nur im Portal haben.
MfG
Frank
talonos
Portal Specialist
Re: [RELEASE]mChat V2.0.2 Board3 extension
Post by talonos »
2.0.2
talonos
Portal Specialist
Re: [RELEASE]mChat V2.1.0 Board3 extension
Post by talonos »
2.1.0
Neves
phpBB.com User: Neves Projects
Post by Neves »
I tried this but when I enable it, it locks me out of my forum and admin. area with this error
Parse error: syntax error, unexpected 'public' (T_PUBLIC) in /home/nevespro/public_html/ext/talonos/b3pmchat/b3pmchat.php on line 28
I have to change talonos name through ftp to get back into my site
And now I can't even disable it because under Manage Extensions I have this
The “talonos/b3pmchat” extension is not valid.
The requested file could not be found: ./../ext/talonos/b3pmchat/composer.json
with no Disable button
Can anyone help with this ?
Thanks
Return to “v2.1.x”
