whois_online Not show bots
demonlibra
phpBB.com User: demonlibra
Post by demonlibra »
Your Portal Version: 2.1.0
PHP Version: 5.3.13
MySQL Version: 5.1.41
Is it possible that module whois_online not show bots?
I Try to edit file ".../ext/board3/portal/modules/whois_online.php" in section below but no result.
if ($row['group_name'] == 'BOTS' || ($this->user->data['user_id'] != ANONYMOUS && !$this->auth->acl_get('u_viewprofile')))
				$legend[] = '<span' . $colour_text . '>' . $group_name . '</span>';
				$legend[] = '<a' . $colour_text . ' href="' . append_sid("{$this->phpbb_root_path}memberlist.{$this->php_ext}", 'mode=group&g=' . $row['group_id']) . '">' . $group_name . '</a>';
[/i]
Re: whois_online Not show bots
Open: root/includes/funtions.php
Find:
        $sql = 'SELECT username, username_clean, user_id, user_type, user_allow_viewonline, user_colour
                FROM ' . USERS_TABLE . '
                WHERE ' . $db->sql_in_set('user_id', $online_users['online_users']) . '
                ORDER BY username_clean ASC';
Replace with:
            AND user_type <> ' . USER_IGNORE . '
demonlibra
Thank you
demonlibra
For PHPBB 3.7.1-PL1
		$sql_ary = array(
			'SELECT'	=> 'u.username, u.username_clean, u.user_id, u.user_type, u.user_allow_viewonline, u.user_colour',
			'WHERE'		=> $db->sql_in_set('u.user_id', $online_users['online_users']),
			'ORDER_BY'	=> 'u.username_clean ASC',
replace
Yes
demonlibra
Sorry, but i dont understand.
phpbb 3.16 have code
phpbb 3.1.7-PL1 have code
		$sql_ary = array(
			'FROM'		=> array(
				USERS_TABLE	=> 'u',
What changes must be done in phpbb 3.1.7?
You should only have to change that to:
      $sql_ary = array(
         'FROM'      => array(
            USERS_TABLE   => 'u',
         'WHERE'      => $db->sql_in_set('user_id', $online_users['online_users']) . ' AND user_type <> ' . USER_IGNORE,
demonlibra
Thank you
