Second news block in center column
MrC
Post by MrC »
What do i have to do to create a working 2nd news block in the center column.
Simple replacing news into news2 didn´t do what i hoped it would do (it didnt work at all)
Thanks in advance
Re: Second news block in center column
Here is a second news block
Download:
b3p_board_lastest_news2_modul.zip
Second News Block
(17.54 KiB) Downloaded 1786 times
Upload the module package via the ACP or just upload the content of the ZIP-File into the root of your forum.
MrC
Post by MrC »
Great, thanks a lot!
I will try this tonight.
MrC
Post by MrC »
I did a quick test, it works but it overrules the settings of the other news module. News1 and news2 show the same news now.
Is it possible to have the 2nd news module to show other forum topics than the 1st?
Thanks in advance
When I have time I check it again
MrC wrote:Is it possible to have the 2nd news module to show other forum topics than the 1st?
I have not found a solution for it, I do not believe it is possible.
MrC
Post by MrC »
Ive seen a KB article here how to modify a module
I will look at it when i have the time and see if i can get it working.
It must be something with writing to and reading from the database
MrC
Post by MrC »
i've been playing with the second new block (in my case meetings block) but it still uses the same database entries as the news block.
Can anybody tell me what i have to change to make the second news block use its own database entries?
**edit** i found the soltion here viewtopic.php?f=23&t=5699
It's fixed now
Nor7on
phpBB.com User: Nor7on
Post by Nor7on »
Mrc
How fix it?
MrC
Post by MrC »
You can download the block from my server
http://www.spaapen.net/ivo/Portal_Meetings.zip
Nor7on
Post by Nor7on »
Thanks Dude!
