Your Portal Version: 1.0.1
I was normally try to install Board 3 in my modificated phpBB 3.0.2
Using phpBB3Portal (www.phpbb3portal.com) instead it !!!
I'm a phpBB3Portal (www.phpbb3portal.com) user and want to migrate to Board 3 because of iy's high feautures,some months age,I was normally try to install Board 3 in my modificated phpBB 3.0.2,but when I want to do my style changes,I've noticed than many things is different...and when I test board 3...all things has been crashed !
Can anyone do Board 3 style changes in my style ?
Doing style changes
Re: Doing style changes
You might just ask here: www.board3-styles.de
I think it would be easier for you to install phpbb3, then board3, then test/install mod by mod. You can set up a local server in your operating system and try the mods out there. Look here on how to set up such a server in under 3 minutes;
http://www.phpbb.com/kb/article/install ... eb-server/
thanks alot,I always test mods in localhost
