[Release] Avatar of poster on Portal
gamingboard
phpBB.de User: gamingboard
phpBB.com User: gamingboard
Post by gamingboard »
Addon: Avatar of poster on Index and Viewforum 1.3.0 for Board3 2.0.1
Addon Version: 1.3.0.1
Addon Author: gamingboard
Addon Description:
Shows the author's avatar and last poster's avatar on the news block (compact style only)
Addon Requirements: Board3 Portal 2.0.1 and Avatar of poster on Index and Viewforum 1.3.0
Download:
phpBB.com (You 'll find the zip at the bottom of my the post)
-Removed second host, because it was useless
Disclaimer and other notes:
Before adding this MOD to your forum, you should back up all files and databases related to this MOD.
This MOD was designed for Avatar of poster on Index and Viewforum 1.3.0 / Board3 2.0.1
and may not function as stated on other Avatar of poster on Index and Viewforum / Board3 versions.
Instructions:
Upload the package with AutoMOD or read the install.xml
Preview:
BetterDeadThanZed
Re: [Release] Avatar of poster on Portal
Post by BetterDeadThanZed »
Is there a way to adjust how large the avatar is displayed? It seems a little big for my forum theme.
gamingboard
My mod inherits the settings from "Avatar of Poster on Index and Viewforum". You have to edit the setting "Maximum dimension for the displaying of the avatar" to change the dimision of the avatars (FYI, Affects only the Avatars on the Index, Viewforum, Forumlist block, Global announcements block and the news block)
Example: (20px)
ALSO:
A new Version is out:
Changelog:
  • Display the Avatar on the "Global announcement block
Codechanges:
gamingboard wrote:Before adding this MOD to your forum, you should back up all files and databases related to this MOD.
Note: This is just a fix for the global announcements block.
Open: portal/modules/portal_announcements.php
                // Grab icons
                $icons = $cache->obtain_icons();
//-- mod : apiv ----------------------------------------------------------------
//-- add
//-- Board3
                if ( $config['avatar_topics_first_poster_show'] || $config['avatar_topics_last_poster_show'] )
                    $template->assign_var('AVATAR_MAX_DIMENSIONS', $config['avatar_max_dimensions']);
//-- fin mod : apiv ------------------------------------------------------------
                    if(!empty($fetch_news[$i]['attachments']))
                        foreach ($fetch_news[$i]['attachments'] as $attachment)
                            $template->assign_block_vars('announcements_center_row.attachment', array(
                                'DISPLAY_ATTACHMENT'    => $attachment)
//-- add
//-- Board3
                    user_display_avatar($fetch_news[$i], 'topic_first', 'announcements_center_row', $config['avatar_topics_first_poster_show']);
                    user_display_avatar($fetch_news[$i], 'topic_last', 'announcements_center_row', $config['avatar_topics_last_poster_show']);
Open: styles/prosilver/template/portal/modules/announcements_center_compact.html
<!-- IF announcements_center_row.S_UNREAD_TOPIC -->
<!-- IF announcements_center_row.TOPIC_FIRST_POSTER_AVATAR --><span style="float: left; padding-top: 3px; margin-right: {announcements_center_row.TOPIC_FIRST_POSTER_AVATAR_MARGIN}px;">{announcements_center_row.TOPIC_FIRST_POSTER_AVATAR}</span><!-- ENDIF -->
<span><dfn>{L_LAST_POST}</dfn>{L_POST_BY_AUTHOR} {announcements_center_row.USERNAME_FULL_LAST} <!-- IF announcements_center_row.S_UNREAD_INFO --><a href="{announcements_center_row.U_VIEW_UNREAD}">{NEWEST_POST_IMG}</a><!-- ELSE --><a href="{announcements_center_row.U_LAST_COMMENTS}">{READ_POST_IMG}</a><!-- ENDIF --><br />
				{announcements_center_row.LAST_POST_TIME}</span>
<!-- IF announcements_center_row.TOPIC_LAST_POSTER_AVATAR --><div style="float: left; padding-top: 0px; margin-left: 5px; margin-right: {announcements_center_row.TOPIC_LAST_POSTER_AVATAR_MARGIN}px;">{announcements_center_row.TOPIC_LAST_POSTER_AVATAR}</div><!-- ENDIF -->
Purge the cache
Enjoy
You can find a MODX Version of this mod here (subsilver2 included, Automod ready [Uninstall the old version first, if you use Automod])
Grab the zip for the new version...
P.s. When you installed this Mod via Automod make sure that you delete the old version first.
