Poral and forum
Current Version: 2.0.2
Released: 2013-10-27
Derradeiro_24
phpBB.de User: 24
phpBB.com User: 24
Poral and forum
Post by Derradeiro_24 »
Your Portal Version: 2.0.1
Hi, sorry if i do something wrong posting this.
Im begginer in phpBB, before i use other foruns CMS...
I want do onething i dont know if it is possible because i never see in phpBB e just saw in vbulletin.
what i want is put the portal in www.hypro-tech.com for exemple and the forum in www.hypro-tech.com/forum or in www.forum.hypro-tech.com
I dont know if it possible like i say i just saw in vbulletin. if you prefer i can say the link of the forum where i see this to you check and understend what im talking
PS: sorry for my english
Re: Poral and forum
You can Board3 Portal with phpBB but not with vbulletin.
Board3 Portal, they can be the first page and not in index.php.
For their styles please read here: Absolution (Base: prosilver)
Derradeiro_24
phpBB.de User: 24
phpBB.com User: 24
Re: Poral and forum
i know i cant use board3 with vbuletin
what i wat know it if is possible put the portal in www.hypro-tech.com and have the forum in forum.hypro-tech.com or hypro-tech.com/forum
Re: Poral and forum
Derradeiro_24 wrote: and have the forum in forum.hypro-tech.com or hypro-tech.com/forum
It should be possible, if they follow all the instructions in the install.xml.
and:
archivar wrote: For their styles please read here: Absolution (Base: prosilver)
Derradeiro_24
phpBB.de User: 24
phpBB.com User: 24
Re: Poral and forum
i already install the portal and work with absolution template.
but its a normal portal its the index but are in the same place with forum. im doing in localhost
i go send to host and try somethings
kentaur
Re: Poral and forum
Post by kentaur »
You should search - how to move portal.php out of forum directory.
Make a copy of /forum/portal.php to the htdocs directory.
Edit the /htdocs/portal.php and change - this line :
so it points to the forum directory, in my case to /forum :
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forum';
now copy .htaccess from the /forum to htdocs and check that it has :
in the /forum edit .htaccess and change DirectoryIndex line to :
DirectoryIndex index.php portal.php index.html index.htm
This way under /forum it doesnt default to portal, but opens forum index.
