Your Portal Version: 2.0.1
Boardlink: not live
No problem
Hello everyone,
I have board3 portal installed on phpbb3.0.11. I'm very happy with the mod and have had no issues with it. I would like to add the announcement block to the index page. Can this be done with board3? What files and what code? Thanks for any help.
Steve
add block to index.php
castlegard
Re: add block to index.php
See it in the ACP in the portal modules and add them.
If they have no announcements on the portal can not be shown announcements.
castlegard
Thanks for the reply. As far as I can tell, everything is working perfectly. I can see the announcements on the portal, but I would also like to add the block to index.php so that global announcements can be seen on different pages.
You can not show a portal module in index.php.castlegard wrote: but I would also like to add the block to index.php so that global announcements can be seen on different pages.
Since this has nothing to do with the portal, they ask for it phpBB.com.
