Move Recent Topics module to left column?
Current Version: 2.0.2
Released: 2013-10-27
kooljp
Post by kooljp »
Your Portal Version: 2.0.1
Boardlink: http://www.fishing-victoria.com/
n/a
cannot move the Recent Topics module from the Centre Column to the left column.
Hi, I cannot move the Recent Topics module from the Centre Column to the left column.
There are no arrows as pictured:
We need to move "Recent" to the Left column.
How do you achieve this?
cpg
Sponsor
phpBB.de User: cpg
Re: Move Recent Topics module to left column?
Post by cpg »
the file in \styles\yourstyle\template\portal\modules
is "recent_center.html"
I think, for the sides you have to write a new "recent_side.html".
Best regards
CPG
Open root/portal/modules/portal_recent.php
Find:
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
	public $columns = 21;
Replace with:
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
	public $columns = 31;
Find:
		return 'recent_center.html';
Add after:
		global $config, $template, $db, $auth, $phpbb_root_path, $phpEx;
		// Exclude forums
		$sql_where = '';
		if ($config['board3_recent_forum_' . $module_id] > 0)
			$exclude_forums = explode(',', $config['board3_recent_forum_' . $module_id]);
			$sql_where = ' AND ' . $db->sql_in_set('forum_id', array_map('intval', $exclude_forums), ($config['board3_recent_exclude_forums_' . $module_id]) ? true : false);
		// Get a list of forums the user cannot read
		$forum_ary = array_unique(array_keys($auth->acl_getf('!f_read', true)));
		// Determine first forum the user is able to read (must not be a category)
		$sql = 'SELECT forum_id
			FROM ' . FORUMS_TABLE . '
			WHERE forum_type = ' . FORUM_POST;
		$forum_sql = '';
		if (sizeof($forum_ary))
			$sql .= ' AND ' . $db->sql_in_set('forum_id', $forum_ary, true);
			$forum_sql = ' AND ' . $db->sql_in_set('t.forum_id', $forum_ary, true);
		$g_forum_id = (int) $db->sql_fetchfield('forum_id');
		$db->sql_freeresult($result);
		// Recent announcements
		$sql = 'SELECT topic_title, forum_id, topic_id
			FROM ' . TOPICS_TABLE . ' t
			WHERE topic_status <> ' . FORUM_LINK . '
				AND topic_approved = 1
				AND (topic_type = ' . POST_ANNOUNCE . ' OR topic_type = ' . POST_GLOBAL . ')
				AND topic_moved_id = 0
				' . $sql_where . '' .  $forum_sql . '
			ORDER BY topic_time DESC';
		$result = $db->sql_query_limit($sql, $config['board3_max_topics_' . $module_id]);
		while(($row = $db->sql_fetchrow($result)) && ($row['topic_title']))
			// auto auth
			if (($auth->acl_get('f_read', $row['forum_id'])) || ($row['forum_id'] == '0'))
				$template->assign_block_vars('latest_announcements', array(
					'TITLE'			=> character_limit($row['topic_title'], $config['board3_recent_title_limit_' . $module_id]),
					'FULL_TITLE'	=> censor_text($row['topic_title']),
					'U_VIEW_TOPIC'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($row['forum_id'] == 0) ? $g_forum_id : $row['forum_id']) . '&t=' . $row['topic_id'])
		// Recent hot topics
			WHERE topic_approved = 1
				AND topic_replies >=' . $config['hot_threshold'] . '
			// auto auth
				$template->assign_block_vars('latest_hot_topics', array(
		// Recent topic (only show normal topic)
			WHERE topic_status <> ' . ITEM_MOVED . '
				AND topic_type = ' . POST_NORMAL . '
			// auto auth
				$template->assign_block_vars('latest_topics', array(
					'U_VIEW_TOPIC'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $row['forum_id'] . '&t=' . $row['topic_id'])
		return 'recent_side.html';
Create a file named recent_side.html with the following content:
<!-- IF .latest_announcements or .latest_hot_topics or .latest_topics -->
		<!-- IF .latest_announcements --><td class="row1"><strong>{L_PORTAL_RECENT_ANN}</strong></td><!-- ENDIF -->
		<!-- IF .latest_hot_topics --><td class="row1"><strong>{L_PORTAL_RECENT_HOT_TOPIC}</strong></td><!-- ENDIF -->
		<!-- IF .latest_topics --><td class="row1"><strong>{L_PORTAL_RECENT_TOPIC}</strong></td><!-- ENDIF -->
		<td class="row1" width="33%" valign="top">
			<!-- BEGIN latest_announcements -->
						<a href="{latest_announcements.U_VIEW_TOPIC}" title="{latest_announcements.FULL_TITLE}">{latest_announcements.TITLE}</a><br />
			<!-- END latest_announcements -->
			<!-- BEGIN latest_hot_topics -->
				<a href="{latest_hot_topics.U_VIEW_TOPIC}" title="{latest_hot_topics.FULL_TITLE}">{latest_hot_topics.TITLE}</a><br />
			<!-- END latest_hot_topics -->
			<!-- BEGIN latest_topics -->
				<a href="{latest_topics.U_VIEW_TOPIC}" title="{latest_topics.FULL_TITLE}">{latest_topics.TITLE}</a><br />
			<!-- END latest_topics -->
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
Upload these file to root/styles/[stylename]/template/potal/module
Refresh your Styles:
"Administration Control Panel" (ACP) > "Styles" > "Theme" > each > "refresh"
The adjustments you have to make yourself
kooljp
Post by kooljp »
now I have an error:
Fatal error: Call to undefined method portal_recent_module::get_template_side() in /home/content/12/7540112/html/portal.php on line 97
You are supposed to add that method as described in the post above. Please take another look at your edits.
kooljp
Post by kooljp »
works perfectly now. Thanks!
