[RELEASE]Warcraft WOW-Heroes Top10 v1.0.1
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Addon: Warcraft WOW-Heroes Top10
Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
Block will display the top10 memebers from the predefined Guild with the listings comming from wow-heroes.com with Mouse over tooltips to display additional infomation
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here: HERE
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
Demo: http://pretereo-stormrage.co.uk/portal.php Blocks on the Left are the current working Modules. others displayed there currently are not available yet unless stated
REVISION INFOMATION
1.0.3
more stabile linking to wow-heroes for accented characters.
1.0.2
Bug fix: link direction now sends you to the right page on wow-heroes.
1.0.1
Bug fix: removed code that blocked block working in Internet Explorer
1.0.0
Initial Release
talonos
Portal Specialist
Re: [RELEASE]Warcraft WOW-Heroes Top10 v1.0.0
Post by talonos »
these mods have been available for 1 month now and no comments. are they free of bugs or just no interest in them until more mods are created for new portal system?
Maybe because it does not work in Internet Explorer? There are many users who use Internet Explorer.
talonos
Portal Specialist
Post by talonos »
Released v1.0.1 to remove code that blocked internet explorer displaying the block (thanks for noticeing Kirk)
talonos
Portal Specialist
Re: [RELEASE]Warcraft WOW-Heroes Top10 v1.0.1
Post by talonos »
1.0.3
1.0.2
gazmon
phpBB.de User: gazmon
phpBB.com User: gazmon
Post by gazmon »
Hi, first off great addon, been using it for a while, I vaguely remember reading a bug that wouldn't allow the tooltip to load until after the guild recently activity tooltip was displayed.
Any fix on this? Or is this still an issue? :)
talonos
Portal Specialist
Post by talonos »
the tooltip issues on this block is an issue with wowheads tooltip script. they are looking into it, currently only way around it is to load (mouseover) a normal item THEN the custom ones will load.
gazmon
Post by gazmon »
Ah that's cool, I couldn't find where I read it before, so thank you very much.
