[OBSOLETE]Warcraft Guild Perks Block v1.0.1
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Addon: Warcraft Guild Perks Block
Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
Block will display current guild level and the current associated perk for the assigned guild. if the assigned guild is not level 25 yet then the perks that have not been gained will be "faded" comapred to the perks that have been gained.
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
THIS BLOCK NO LONGER WORKS due to changes within world of warcraft
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
Demo: http://pretereo-stormrage.co.uk/portal.php Blocks on the Left are the current working Modules. others displayed there currently are not available yet unless stated
REVISION INFOMATION
1.0.1
Bug fix: removed code that blocked block working in Internet Explorer
1.0.0
Initial Release
talonos
Portal Specialist
Re: [RELEASE]Warcraft Guild Perks Block v1.0.0
Post by talonos »
Released v1.0.1 to remove some old internet explorer blocking code.
talonos
Portal Specialist
Re: [RELEASE]Warcraft Guild Perks Block v1.0.1
Post by talonos »
due to changes in the battle.net api future releases of this module will require an apikey from blizzard. its a very easy process and only has to be done once as the apikey will be cross compatable with the other battle.net api blocks. these blocks will NEVER REQUIRE a person to login to battle.net to view the contents of the block. the apikey is just a onetime thing that will require you to input a code into the ACP for the block once you have recieved
if you would like to get your APIKEY before hand then feel free to goto https://dev.battle.net to create your api account and recieve you APIKEY to apply in the ACP once the module is updated
talonos
Portal Specialist
Post by talonos »
