[BUG] Forumlist block with many suforums in IE9
Current Version: 2.0.2
Released: 2013-10-27
diogodine
Post by diogodine »
Your Portal Version: 2.0.1
Boardlink: http://www.equipeggt.com.br/forum
Create many subforums.
nothing
i add many subforums in my forum list, and now the forumlist block broken my layout when displayed in Internet Explorer 9, in other browser like Firefox or Google Chrome, the viewing is normal.
This happens in my actual theme proFormell and in defaut theme (prosilver). If i delete the subforums or disable forumlist block, the layout is displayed normally.
Image 01 - Displayed in IE9
Image 02 - Displayed in IE9
Image 03 - Displayed in Firefox
How I solve this problem?
My site is http://www.equipeggt.com.br/forum this problem it is online.
Mod installed list:
thanks for post v1.3.5
mchat v1.3.5
Board3Portal 2.0.1
This BUG already existed before installing MODs
Sorry my bad english. I am Brazilian.
diogodine
Re: [BUG] Forumlist block with many suforums in IE9
Post by diogodine »
I forgot to say, if I clik in Compatibility View button Image in IE9 in the Address bar, the layout is displayed normally.
Anyone can help me to fix it?
I see no error, neither in IE8, FF, Chrome, Operea
diogodine
Post by diogodine »
Then the error is only in IE9, I tested in several PCs and all showed the bug in Internet Explorer 9 as shown in the pictures.
Take the test in IE9.
diogodine
Post by diogodine »
someone to help me? I could not solve the problem.
heiner
phpBB.de User: HirschHeinrich
Post by heiner »
Hi, perhaps try this - https://www.phpbb.com/community/viewtop ... rum+column.
I think that's what you are looking for and needed.
After install the listed order also appears in board3portal.
I'm also use this mod on my board.
Greetings Heiner
U'r forum comes without any styleproblems.
