Banner or Picture
Evergood
phpBB.de User: Ever
phpBB.com User: ever
Banner or Picture
Post by Evergood »
Your Portal Version: 2.0.1
On top right hand side of the portal page can a picture or banner be put in that spot and be link to that company? Thanks Don
Re: Banner or Picture
You can easily do that with a custom block. A custom block can contain either BBCode or HTML code.
Evergood
phpBB.de User: Ever
Post by Evergood »
Is that something i can get you to do ?
That is something you can easily do yourself.
Evergood
phpBB.de User: Ever
Post by Evergood »
I would like to put it below the search button and advanced search in the blue area of this page.
The module simply move to the position where you want it.
Evergood wrote:I would like to put it below the search button and advanced search in the blue area of this page.
If they want to do that then they ask on phpBB.com.
There you can not insert a block of B3P!
