[solved/not problem] Some minor wierd problem with RC3
Onetimer
Post by Onetimer »
This was a new clean install without any further mods.
Reinstalled the Board3 mod from scratch.
I just made a new clean install of Board 3 RC3 over a new phpBB3.02 installation. After the install I get this though;
What could be wrong here?
Steve_B
Re: Some minor wierd problem with RC3
Post by Steve_B »
It is not finding the CSS file. So you might like to check that you have uploaded the CSS file and also make sure that you have amended the styles/yourstyle/theme/stylesheet.css and uploaded that as well. Hope this helps out a little.
Ice
Post by Ice »
Also go ACP -> Styles -> Themes -> prosilver -> Refresh
Onetimer
Post by Onetimer »
Thanks guys, apparently resetting the cache on the general tab in the ACP was not enough... ;)
