what change in that code
Current Version: 2.0.2
Released: 2013-10-27
sergeevkatalina
Post by sergeevkatalina »
Your Portal Version: 2.0.1
I want paste game on my portal page, but smth is wrong.
I created custom block and pasted code:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="800" height="480" id="omgpop"><param name="movie" value="http://flashcdn.omgpop.com/embedder.swf?key=33b4d92016180169b878bf6383cd2a5085e0b2154741c99c1d98e32864ea5bae18daa08366adf14751189def4ab0766f172d05c0bc13" /><param name="allowScriptAccess" value="always" /><param name="allowFullScreen" value="true" /><embed src="http://flashcdn.omgpop.com/embedder.swf?key=33b4d92016180169b878bf6383cd2a5085e0b2154741c99c1d98e32864ea5bae18daa08366adf14751189def4ab0766f172d05c0bc13" width="800" height="480" type="application/x-shockwave-flash" allowScriptAccess="always" allowFullScreen="true" name="omgpop" ></embed></object><br/><a href = "http://www.omgpop.com">Play fun multiplayer games</a>
but it doesnt work, it shows only code itself as text. As i understand i need
re-write this HTML-code to make it work in custom block. But how?
On previous version of portal all worked.
p.s. code is correct u can check easily so problem in portal[/i]
Re: what change in that code
You must at Activate BBCode for the custom block set to no.
