Your Portal Version: 3.0.11
There is a National Flags plugin:
https://www.phpbb.com/customise/db/mod/national_flags/
It shows the flags on the forum, but not the portal page. Is it possible to show it on the portal page as well?
National Flags on Portal
Re: National Flags on Portal
National Flags on board 3 portal 2.x
Create a new php file called: portal_flags.php
Put the following inside that file:
Save this file to: root/portal/modules/
Create a new php file called: portal_flags_module.php
save this file to: root/language/en/mods/portal/
Create a new html file called: flags_center.html
put the following inside that file:
Save this file to: root/styles/your-style/template/portal/modules/
Refresh templates
Add your new national flags block
* @package Board3 Portal v2 - Team
* @copyright (c) Board3 Group ( www.board3.de ) , theriddler ( http://www.phpbbservice.nl )
* @ignore
if (!defined('IN_PHPBB'))
exit;
* @package Team
class portal_flags_module
* top 1
* left 2
* center 4
* right 8
* bottom 16
public $columns = 21;
* Default modulename
public $name = 'PORTAL_FLAGS';
* Default module-image:
public $image_src = 'portal_custom.png';
* module-language file
public $language = 'portal_flags_module';
* custom acp template
public $custom_acp_tpl = '';
global $config, $user, $phpEx, $phpbb_root_path;
//Begin: National_Flag
if (!empty($config['allow_flags']))
if (!function_exists('top_flags'))
include($phpbb_root_path . 'includes/functions_flag.' . $phpEx);
top_flags();
//End: National_Flag
return 'flags_center.html';
return array(
'title' => 'PORTAL_FLAGS',
'vars' => array(),
* API functions
function install($module_id)
return true;
function uninstall($module_id)
return true;
* DO NOT CHANGE
exit;
$lang = array();
// DEVELOPERS PLEASE NOTE
'PORTAL_FLAGS' => 'National flags',
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{$IMAGE_SRC}" width="{$IMAGE_WIDTH}" height="{$IMAGE_HEIGHT}" alt="" /> <!-- ENDIF -->{$TITLE}{$LR_BLOCK_H_R}
<span style="width:100%;"><!-- BEGIN fnum --><span style="width:10%;float:left;text-align:center;">{fnum.FLAG}<br />{fnum.L_FLAG_USERS}</span><!-- END fnum --></span><br style="clear:both" />
Refresh templates
habe die Dateien erstellt und meinem Portal hinzugefügt. Soweit so gut!
Nun das Problem, die Darstellung ist nicht Perfekt.
Siehe meine Portalseite ganz unten ---> http://www.elongated-coin.de/phpBB3/portal.php
Gibt es eine Möglichkeit mehr abstand zwischen den Flaggen zu bekommen und sie Zentrieren!?
Es müsste so aussehen wie auf meiner Indexseite ganz unten.
Was ich noch besser fände wäre die Flaggen in einem Modul ganz unten.
Admin von www.elongated-coin.de
Probier mal bei <span style="width:10% dieses zu erhöhen.
Hi,Kirk wrote:Hallo
habe <span style="width:20% eingestellt und es ist jetzt Perfekt!
Danke für die schnelle Hilfe!
Gruß Z-MANN
