Your Portal Version: 3.0.11
Could anybody help to implement the Facebook Like Box module. The description of the Like Box is here:
https://developers.facebook.com/docs/re ... /like-box/
and it alows to generate a code in HTML5, XFBML, IFRAME and URL format.
Thank you!!!
Request: Facebook Like Box Module
greybox
- phpBB.com User: greybox
- phpBB.de User: Kirk
Re: Request: Facebook Like Box Module
Create a custom block and put the code in there. At Activate BBCode for the custom block must be set to no.
greybox
iframe code works, thank you very much!!Kirk wrote:Create a custom block and put the code in there. At Activate BBCode for the custom block must be set to no.
