Your Portal Version: -
I'm using prime birthdate mod to hide age from users profiles but it still shows up in birthday announcements with boardportal Is there anywhere i can modify the age even if i just change it to 00. i've tried searching and searching and cannot find a solution any help would be appreciated.
Thanks
Searching phpbb.com for solutions
please help
Hide Age From Birthday List
Chumbawamba
- phpBB.com User: Chumbawamba
Re: Hide Age From Birthday List
Search them in root / portal / modules / portal_birthday_list.php and remove this code:
if ($age = (int) substr($row['user_birthday'], -4))
$birthday_list .= ' (' . ($now['year'] - $age) . ')';
}Code: Select all
$birthday_ahead_list .= ' (' . ($now['year'] - $age) . ')';
}V.G. archivar
Chumbawamba
Thanks did the trick.
