Your Portal Version: 2.01
Boardlink: http://www.ps2onlinegaming.com
Nothing
Tried installing another theme but with the same result.
We have been using your portal for almost a year now and it runs great. There is one problem that I have not been able to solve however. When using Mozilla Firefox, the left modules are the right width and looks like they should be. With Chrome/Chromium/ and Internet Explorer, the modules are wider and the text is centered which makes the site look sort of goofy. I thought it was a problem with our theme as it is a few versions out of date with phpbb, but using the latest prosilver special edition I get the same result. I am not sure if it is a problem with the board or maybe with the installation I have.
Modile Alignment in Chrome/Other
Favrenation
Re: Modile Alignment in Chrome/Other
I think it is because of the content (code) in their own built module "links".Favrenation wrote: Boardlink: http://www.ps2onlinegaming.com
Disable it built its own module "links", they see if the problem still exists.
