Portal Width
deanandeva
Portal Width
Post by deanandeva »
Boardlink: http://www.discussuc.com
Scanned through this board for related topics
Nothing as yet
My portal seems to not resize itself, when I view it on my widescreen machines its fine, but when I view it on an older laptop that is 4:3 ratio the portal doesnt fit on the screen, you have to scroll left or right to view it?
This used to work so I must have changed something, is there a way to get it back to an auto width setting ?
This is what I have in my center custom block I guess this is causing the problem
<div style="font-size: 1.1em; background-color: #ECF1F3; margin: 0px auto; text-align: center;">
    <a href="http://www.discussuc.com/viewtopic.php?f=0&t=2525"><img src="websponsor.jpg" alt="Click here for details " /></a>
Appreciate your help
Cheers
Dean[/i]
Re: Portal Width
Your Web sponsor graphic is definitely causing the problem. 850px wide! This takes more than a 15'' screen resolution.
btw: this is definitely not the RC3 you are using. ;)
deanandeva
Re: Portal Width
Hi kevin,
Thanks although when I take the above code out of the center block it works fine ?
I am running 3.0.1 and need to upgrade to 3.0.2
Appreciate your help, do you have nay code samples for the center block?
Cheers
