Your Portal Version: 2.0.1
Boardlink: http://talkagenda.com
I initially had it redirect to the Portal after login, but now I want it redirect to Index page after login. After doing the edits (see knowledge/kb_show.php?id=10) it redirects to index after LOGOUT but not after LOGIN. I only want it to go to the index after login, not after logout
I followed the instructions here: knowledge/kb_show.php?id=10
Return to Index
Togbish
- phpBB.de User: Togbish
- phpBB.de User: Kirk
Re: Return to Index
Open: root/styles/prosilver/template/portal/modules/login_box_side.html
Find:
Replace with:
Refresh your Styles:
"Administration Control Panel" (ACP) > "Styles" > "Theme" > each > "refresh"
Find:
<input type="hidden" name="redirect" value="{U_PORTAL}" />Code: Select all
<input type="hidden" name="redirect" value="{U_INDEX}" />"Administration Control Panel" (ACP) > "Styles" > "Templates" > each > "refresh"
Togbish
Re: Return to Index
Great. Worked. Thanks.
May I suggest the last edit be made part of the instructions that I followed. It may save someone else another post here.
