breadcrumbs.html is blank?
Fortis
phpBB.de User: Fortis
phpBB.com User: Fortis
Post by Fortis »
Boardlink: http://www.thedrillersconsortium.com/forum
installed shoutbox
nothing
im trying to install board3 on my Forum with the Subsilver based theme CodFaction and im the last few steps.
Instructions say Find
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187;
Then Find in Line
Then add to Line
The problem is that my breadcrumbs.html file is completely blank, any idea on what to do?[/i]
Re: breadcrumbs.html is blank?
This has nothing to do with the portal it, please contact the Style Creator or http://www.phpbb.com/
Note also that here: viewtopic.php?p=32418#p32418
Fortis wrote:Your Portal Version: 1.0.0RC3
??? :o
Fortis wrote: The problem is that my breadcrumbs.html file is completely blank, any idea on what to do?
You can ignore. ;)
For the style with B3P v.2.0.1 change they do not have the breadcrumbs.html.
See it here: viewtopic.php?f=47&t=3907
You should use only B3P v.2.0.1 with Style for phpBB version: phpBB 3.0.11
Return to “Styles Support”
