Your Portal Version: 2.0.1
Boardlink: http://jaysonberger.com/forums
I have searched the forum board here and found a couple things simular but it was for a different sty;e
I Am using the standard phpbb prosilver style, I do not know much about coding and stuff, i looked it up and figured out how to change from a fluid width to a fixed width, and changed the logo and the header background and a couple colors , thats about the extent of customization i have did...
The problem i am having is the page looks fine when its full screen but when i go to minamize it the right coloum is not staying within the wrap
so i was wondering what is the code i need to make sure the left and right sidebar is contained in the wrap and does not go outside of it....
the article i read did say something about editing
portal_body.html
But not sure what edits need to be made, if someone could advise me on what to do that would be great, thanks in advance.
Portal body wrap for prosilver
jason102178
- phpBB.de User: jason12178
- phpBB.com User: jason102178
Re: Portal body wrap for prosilver
This has nothing to do with the portal. Please Inquire about the problem on phpBB.com.
jason102178
Oh i thought this would be something i would post for portal because if i disable portal and i minamize everything it looks great but when i enable portal the right sidebar doesnt stay contained within it it goes outside of the body
and i found this article were the person was having a simular issue except there sidebar wasnt showing up and it looked crunched like mind kinda
heres the topic
viewtopic.php?f=36&t=4177&p=25902&hilit=wrap#p25902
Because i have a feeling if i tell them i have a mod board portal3 installed and ask how to contain it within a wrap they will tell me the same thing you did, that i should contact you guys
"durangod »"im having trouble getting the sides of boxes to show and also getting the page spaced out, its all crunched together..
heres the topic
What width did you choose? If your width is too small it will not properly show. You should also make sure that you set a minimum width.
