SQL ERROR
Scary
SQL ERROR
Post by Scary »
Your phpBB Version: 3.0.2
i got this error
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND in_message = 0 ORDER BY filetime DESC' at line 4 [1064]
SQL
SELECT * FROM phpbb_attachments WHERE `post_msg_id` = AND in_message = 0 ORDER BY filetime DESC
BACKTRACE
FILE: includes/db/mysql.php
LINE: 158
CALL: dbal->sql_error()
FILE: portal/includes/functions.php
LINE: 283
CALL: dbal_mysql->sql_query()
FILE: portal/block/news.php
LINE: 30
CALL: phpbb_fetch_posts()
FILE: portal.php
LINE: 115
CALL: include('portal/block/news.php')
Can any help,sorry may bad ingles
Greets
Scary[/i]
Re: SQL ERROR
Link to your form?
Scary
Re: SQL ERROR
Post by Scary »
Hi!
I try in LOCALHOST, before i change to my main forum, i've a phpbb3 1.2.2 portal instaled, but i want yours!
That error only appears when i select "no" in the "compact news block style" on the "acp"
Danke!
Scary
Re: SQL ERROR
Scary wrote:i've a phpbb3 1.2.2 portal instaled
With which portal do you receive this error? With the phpbb3 1.2.2 portal or ours?
Scary
Re: SQL ERROR
Post by Scary »
i've already put yours. And everything's fine...
except that error when I select "no" in the "compact news block style" on the "acp"
Scary
Scary
Re: SQL ERROR
Post by Scary »
SQL
SELECT * FROM phpbb_attachments WHERE post_msg_id = AND in_message = 0 ORDER BY filetime DESC
BACKTRACE
LINE: 174
LINE: 283
LINE: 30
FILE: portal.php
LINE: 115
my forum test is http://www.scarymule.com/ftestes/portal.php
Greets
Scary
Re: SQL ERROR
Already solved? I dont see no error on your site.
Scary
Re: SQL ERROR
Post by Scary »
Kevin wrote:Already solved? I dont see no error on your site.
not solved the link is http://www.scarymule.com/ftestes/portal.php not http://www.scarymule.com/ftestes/
Scary
Re: SQL ERROR
Still no error. :?
Do receive this error as a guest too?
Scary
Re: SQL ERROR
Post by Scary »
Kevin wrote:Still no error. :?
as a guest, i don't receive an error, only logged...
sorry a double post
Scary
Re: SQL ERROR
Post by Scary »
please ,can any help! :cry: :cry:
Re: SQL ERROR
A test account would be helpful, as the error doesn't occur for guests.
Sorry for the limited support, but i'm not at home, i'm in holidays. ;)
Scary
Re: SQL ERROR
Post by Scary »
test account is:
user=test
password=123456
thanks
Scary
Re: SQL ERROR
Post by Scary »
this error only appears if I have the attach active in ACP -> General -> Board Configuration -> Attachment settings -> Attachment display order, if I deactivate, the error doesn't appear.
greet
Cumps
Ice
Re: SQL ERROR
Post by Ice »
Seems the error is caused by a missing id.
Open /portal/includes/functions.php
		if( $config['allow_attachments'] )
		if( $config['allow_attachments'] && $row['post_id'] )
