White portal as no theme
Weltall
phpBB.com User: Weltall
Post by Weltall »
Your Portal Version: 2.0.1
Boardlink: http://clandecima.altervista.org/forum/portal.php
PHP Version: 3.0.11
MySQL Version: 5.1
I updated my portal version to 1.0.6 to 2.0.0 and then to 2.0.1
I unistalled portal, then made a fresh install to 2.0.1
Hello
I just updated my 1.0.6 portal installation (it worked perfectly) to a 2.0.0 but the installation didn't went fine.
I had a kind of white screen, other functions like acp seems to work fine. during the installation I got 1 error abour permissions, but everything else was fine.
So i deleted all files with portal in the name and then tried a fresh install directly from 2.0.1
But it gave me same errors and same white screen.
My template is hermes, based on subsilver2
This is a screenshot of my portal
Any help would be really appreciated!
Thanks
Re: White portal as no theme
See it here and follow the instructions for the Style Hermes (Base: subsilver2)
Weltall
Post by Weltall »
Thanks a lot!
Problem solved :))
Return to “Styles Support”
