How upgrade my old version?
Current Version: 2.0.2
Released: 2013-10-27
Opiam
Post by Opiam »
Your Portal Version: 1.0.6
Boardlink: http://localhost/portal.php
MySQL Version: 5.5.28
nothing
nothing
Help me plz. I need update my old 1.0.6 to the last 2.0.1 but i don'y know how I can do it.. plz. thx.
Re: How upgrade my old version?
You can either try to convert your 1.0.6 to 2.0.0 and then update to 2.0.1 or you can uninstall 1.0.6 and install 2.0.1. The downside of using the converter is that it might cause issues; especially if you have any additional blocks installed.
The downside of uninstalling 1.0.6 and installing 2.0.1 is of course that you loose your settings. This way is usually better since it causes less issues though.
