[RELEASE] Board3 Portal 2.0.1 - English
MOD-Titel: Board3 Portal
MOD-version: 2.0.1
MOD-description:
Image Valid XHTML 1.0 Strict
Adds a portal with several blocks to your forum. You can change the settings, move the blocks, add new blocks and more in the ACP.
Changes to version 2.0.0
  • Redirect to portal.php when detecting incorrect announcement parameter
  • Add rel="nofollow" to calendar navigation
  • Fixed incorrect handling of months by strtotime
  • Fix previous commit for calendar
  • Fix incorrect config_name in portal_recent.php
  • Fix error if server-side topic marking is disabled
  • Fix incorrect space between blocks in IE9
  • [ticket/203] Future all day events are always displayed as current
  • [ticket/207] Debug warning in ACP when using PHP 5.4
  • [ticket/206] Missing link to MCP in subsilver2
  • Fix PHP notice when unable to rename
  • Fix incorrect space above calendar in IE9
  • Properly handle mutated vowels in links
  • Enable stylechanger for guests again
  • Add missing language var for logs after removing a link
  • Remove converter for Board3 Portal 1.0.6
  • Fix: Infinite loop caused by smiley code with "["
  • Fix: Only variables can be passed by ref in strict mode
  • Display events that start in the next 24 Hours as "Current"
  • Remove unnecessary variables from format_birthday() & clean-up
  • Save module settings even if module image can't be found
  • Add missing error messages to links & main menu modules
  • Remove update instructions for old releases
  • Remove update for beta version
  • Add missing language variable "NO_FILE_B3P"
MOD-authors: Marc, nickvergessen, Kevin, Ice, Christian_N, Redbull254
MOD-download: php-version: PHP 5.+
phpBB-version: phpBB 3.0.11
phpBB-styles: prosilver, subsilver2
phpBB-languages: English, German - More languages here: viewforum.php?f=55
MOD-demo: soon
Portal ACP Demo: soon
Preview install instructions: soon
Return to “Board3 Portal Releases / Download”
