Broken Board3 Portal - prosilver_se issue
Cypriotmatrix
phpBB.com User: Cypriotmatrix
Post by Cypriotmatrix »
my Board3 Portal seems to be broken.
http://cyprus-forum.net/portal.php?style=2
I do not know how to solve this issue and would like some assistance in resolving it.
So far I have tried uninstalling Board3Portal and reinstalling it but that has not worked.
Kind Regards
Cypriotmatrix
Re: Broken Board3 Portal - prosilver_se issue
Still have the same ongoing issue and am frustratingly trying to solve it.
Can I please have some assistance?
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
seems, that you did not upload all files.
Check the instructions point for point.
Check the files in the styles/yourstyle/template folder!
Best regards
CPG
The requested URL /styles/prosilver_se/theme/portal.css was not found on this server.
You have in the / styles / prosilver_se / theme / stylesheet.css
Here the
@ import url ("portal.css");
4x too much.
Cypriotmatrix
Kirk wrote:Hi
Here the
4x too much.
thank you for your reply.
I copied the Portal.css to /styles/prosilver_se/theme
It is there now. I refreshed the template and the theme in ACP, but still the Portal appears broken in the Prosilver theme.
This is the code in Portal.css:
/* inner corners */
span.portal-corners-top-inner {
	margin: 0 -5px;
span.portal-corners-bottom-inner {
	margin: 0 -5px;
	clear: both;
span.portal-corners-top-inner, span.portal-corners-bottom-inner{
	font-size: 1px;
	line-height: 1px;
	display: block;
	height: 5px;
	background-repeat: no-repeat;
/* main menu, user menu and the links */
.portal-navigation{
	width: auto;
.portal-navigation ul{
	list-style-type: none;
	margin: 0;
	padding: 0;
	margin-bottom: 8px; /*bottom spacing between each UL and rest of content*/
.portal-navigation ul li{
	padding-bottom: 2px; /*bottom spacing between menu items*/
.portal-navigation ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/arrowbullet.gif");
	background-position: center left; /*custom bullet list image*/
	display: block;
	padding: 2px 0;
	padding-left: 19px; /*link text is indented 19px*/
	font-weight: bold;
	font-size: 90%;
.portal-navigation div.menutitle{
	padding: 1px 0;
	font: bold 90% 'Trebuchet MS', 'Lucida Grande', Arial, sans-serif;
	font-size: 12px;
.calendar-info {
.portal-events li.row
	border-top: 0px;
* top spacing between portal body table and headerbar spacing is usually 10px
#portal-body {
	padding-top: 10px;
* This is needed in order to have the same spacing between blocks
* as we have between the top blocks and the headerbar
#portal-body .forabg {
	margin-bottom: 0px;
* margin spacing as in default prosilver for the forumlist
#portal-forumlist .forabg {
	margin-bottom: 4px;
/* RTL language fixes */
.rtl .portal-navigation ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/arrowbullet_rtl.gif");
	background-position: center right; /*custom bullet list image*/
	padding-right: 19px; /*link text is indented 19px*/
Maybe there is something wrong in there. :?
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
here ist the portall.css from my site:
/* inner corners */
        margin: 0 -5px;
        margin: 0 -5px;
        clear: both;
        font-size: 1px;
        line-height: 1px;
        display: block;
        height: 5px;
.portal-navigation{
        width: auto;
        margin: 0;
        padding: 0;
        display: block;
        padding: 2px 0;
        font-weight: bold;
        font-size: 90%;
.portal-navigation-new-posts ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/new_posts.png");
       display: block;
       padding: 8px 0 7px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-unread-posts ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/unread_posts.png");
       display: block;
       padding: 8px 0 8px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-self-posts ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/self_posts.png");
       display: block;
       padding: 8px 0 10px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-bookmarks ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/bookmark.png");
       display: block;
       padding: 3px 0 6px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-main-subscribed ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/subscribed.png");
       display: block;
       padding: 5px 0 5px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-private-mesage-info ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/pm.png");
       display: block;
       padding: 6px 0 6px 21px;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-profile ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/profile.png");
       display: block;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-mcp ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/moderator.png");
       display: block;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-acp ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/acp.png");
       display: block;
       font-weight: bold;
       font-size: 90%;
.portal-navigation-login-logout ul li a{
       background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/logout.png");
       display: block;
       font-weight: bold;
       font-size: 90%;
        padding: 1px 0;
        font-size: 12px;
.calendar-info {
        border-top: 0px;
#portal-body {
        padding-top: 10px;
        margin-bottom: 0px;
        margin-bottom: 4px;
Regards
CPG
Cypriotmatrix
cpg wrote:Hallo,
/* inner corners */
        margin: 0 -5px;
        margin: 0 -5px;
        clear: both;
        font-size: 1px;
        line-height: 1px;
        display: block;
        height: 5px;
.portal-navigation{
        width: auto;
        margin: 0;
        padding: 0;
        display: block;
        padding: 2px 0;
        font-weight: bold;
        font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
       display: block;
       font-weight: bold;
       font-size: 90%;
        padding: 1px 0;
        font-size: 12px;
.calendar-info {
        border-top: 0px;
#portal-body {
        padding-top: 10px;
        margin-bottom: 0px;
        margin-bottom: 4px;
Regards
CPG
Thanks for that.
I tried your code and unfortunately I still get the same result. I also refreshed in ACP.
So obviously it can't be the Portal.Css.
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
please post your / prosilver_se / theme / stylesheet.css
Regards
CPG
Cypriotmatrix
cpg wrote:Hallo,
Regards
CPG
Strylesheet.css
/*  phpBB3 Style Sheet
	Style name:			prosilver Special Edition
	Based on style:		prosilver (the default phpBB 3.0.x style)
	Original author:	Tom Beddard ( http://www.subblue.com/ )
	Modified by:		phpBB Group ( http://www.phpbb.com/ )
@import url("common.css");
@import url("links.css");
@import url("content.css");
@import url("buttons.css");
@import url("cp.css");
@import url("forms.css");
@import url("tweaks.css");
@import url("portal.css"); was there 4 times for some reason. I didn't make this edit so I am not sure how that hapenned. I edited and left only 1 @import url("portal.css");
I then refreshed theme in ACP but still the problem persists.
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
something happened on your site - but it is not really ok :)
Is it a new installation or an update?
Did you check all files you had to upload?
Regards
CPG
Have you refreshed template in ACP by all styles?
Cypriotmatrix
Kirk wrote:Have you refreshed template in ACP by all styles?
Yes I have regreshed the template for both Prosilver and Prosilver_se but this still has not fixed it. :(
Cypriotmatrix
cpg wrote:Hallo,
Regards
CPG
Yes you are not wrong. I am checking the files to see if something is missing.
I am wondering if I should uninstall and reinstall the portal from scratch. But if I do that, is all my work so far gone to waste?
The only ediots I have done as of late were in the overall_header and colours.css. I added the social icons but since then something went wrong.... :?
Your /styles/prosilver_se/template/portal/_block_config.html is for subsilver2 nor for prosilver.
Cypriotmatrix
Kirk wrote:Your /styles/prosilver_se/template/portal/_block_config.html is for subsilver2 nor for prosilver.
What do you mean?
Do I copy the block-config.html to prosilver_se?
Return to “Styles Support”
