[Release] Portal Listenpunkte im Benutzer-Menü austauschen
Name: Portal Listenpunkte im Benutzer-Menü (user_menu_side.html) austauschen.
Portal List points exchange in User menu.
Beschreibung: Ersetzt die Listenpunkte im user_menu_side.html gegen individuelle.
Replaces the list points in user_menu_side.html against individual.
Getestet mit Board3 Portal 2.0.0 / Tested with Board3 Portal 2.0.0
[+] Install Instructions
Instructions for prosilver based styles
Open: root/styles/[stylename]/template/portal/modules/user_menu_side.html
Find:
	<div class="portal-navigation">
		<div class="menutitle">{L_M_MENU}</div>
			<ul>
				<!-- IF S_DISPLAY_SEARCH -->
					<li><a href="{U_NEW_POSTS}">{L_NEW_POSTS}</a></li>
					<li><a href="{U_UNREAD_POSTS}">{L_UNREAD_POSTS}</a></li>
					<li><a href="{U_SELF_POSTS}">{L_SELF_POSTS}</a></li>
				<!-- IF U_UM_BOOKMARKS -->
					<li><a href="{U_UM_BOOKMARKS}">{L_UM_BOOKMARKS}</a></li>
				<!-- IF S_DISPLAY_SUBSCRIPTIONS -->
					<li><a href="{U_UM_MAIN_SUBSCRIBED}">{L_UM_MAIN_SUBSCRIBED}</a></li>
				<!-- IF S_DISPLAY_PM -->
					<li><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></li>
				<li><a href="{U_PROFILE}">{L_PROFILE}</a></li>
				<!-- IF U_UM_MCP -->
					<li><a href="{U_UM_MCP}">{L_MCP}</a></li>
				<!-- IF U_ACP -->
					<li><a href="{U_ACP}">{L_M_ACP}</a></li>
				<li><a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a></li>
Replace with:
	<div class="portal-navigation-new-posts">
			<ul>
	<div class="portal-navigation-unread-posts">
			<ul>
	<div class="portal-navigation-self-posts">
			<ul>
	<div class="portal-navigation-bookmarks">
			<ul>
	<div class="portal-navigation-main-subscribed">
			<ul>
	<div class="portal-navigation-private-mesage-info">
			<ul>
	<div class="portal-navigation-profile">
			<ul>
	<div class="portal-navigation-mcp">
			<ul>
	<div class="portal-navigation-acp">
			<ul>
				<!-- IF U_ACP -->
	<div class="portal-navigation-login-logout">
			<ul>
Open: root/styles/[stylename]/theme/portal.css
Find:
.portal-navigation ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/arrowbullet.gif");
	background-repeat: no-repeat;
	background-position: center left; /*custom bullet list image*/
	display: block;
	padding: 2px 0;
	padding-left: 19px; /*link text is indented 19px*/
	font-weight: bold;
	font-size: 90%;
After add:
.portal-navigation-new-posts ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/new_posts.png");
	display: block;
	padding: 8px 0 7px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-unread-posts ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/unread_posts.png");
	display: block;
	padding: 8px 0 8px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-self-posts ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/self_posts.png");
	display: block;
	padding: 8px 0 10px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-bookmarks ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/bookmark.png");
	display: block;
	padding: 3px 0 6px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-main-subscribed ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/subscribed.png");
	display: block;
	padding: 5px 0 5px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-private-mesage-info ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/pm.png");
	display: block;
	padding: 6px 0 6px 21px;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-profile ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/profile.png");
	display: block;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-mcp ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/moderator.png");
	display: block;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-acp ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/acp.png");
	display: block;
	font-weight: bold;
	font-size: 90%;
.portal-navigation-login-logout ul li a{
	background-image: url("{T_THEME_PATH}/images/portal/user_menue_icons/logout.png");
	display: block;
	font-weight: bold;
	font-size: 90%;
For subsilver2 based styles
Find:
	<tr class="row1">
		<td>
			<a href="{U_NEW_POSTS}" title="{L_NEW_POSTS}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_NEW_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UNREAD_POSTS}" title="{L_UNREAD_POSTS}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_UNREAD_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_SELF_POSTS}" title="{L_SELF_POSTS}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_SELF_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UM_BOOKMARKS}" title="{L_UM_BOOKMARKS}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_UM_BOOKMARKS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UM_MAIN_SUBSCRIBED}" title="{L_UM_MAIN_SUBSCRIBED}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_UM_MAIN_SUBSCRIBED}</a>
	<tr class="row1">
		<td>
			<a href="{U_PRIVATEMSGS}" title="{L_MESSAGE}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{PRIVATE_MESSAGE_INFO}</a>
	<tr class="row1">
		<td>
			<a href="{U_PROFILE}" title="{L_PROFILE}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_PROFILE}</a>
	<!-- IF U_MCP -->
	<tr class="row1">
		<td>
			<a href="{U_MCP}" title="{L_MCP}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_MCP}</a>
	<!-- IF U_ACP -->
	<tr class="row1">
		<td>
			<a href="{U_ACP}" title="{L_M_ACP}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_M_ACP}</a><br />
	<tr class="row1">
		<td>
			<a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}"><img src="{T_THEME_PATH}/images/portal/arrowbullet<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.gif" width="12" height="11" alt="" />&nbsp;{L_LOGIN_LOGOUT}</a>
Replace with:
	<tr class="row1">
		<td>
			<a href="{U_NEW_POSTS}" title="{L_NEW_POSTS}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/new_posts<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_NEW_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UNREAD_POSTS}" title="{L_UNREAD_POSTS}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/unread_posts<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_UNREAD_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_SELF_POSTS}" title="{L_SELF_POSTS}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/self_posts<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_SELF_POSTS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UM_BOOKMARKS}" title="{L_UM_BOOKMARKS}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/bookmark<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_UM_BOOKMARKS}</a>
	<tr class="row1">
		<td>
			<a href="{U_UM_MAIN_SUBSCRIBED}" title="{L_UM_MAIN_SUBSCRIBED}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/subscribed<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_UM_MAIN_SUBSCRIBED}</a>
	<tr class="row1">
		<td>
			<a href="{U_PRIVATEMSGS}" title="{L_MESSAGE}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/pm<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{PRIVATE_MESSAGE_INFO}</a>
	<tr class="row1">
		<td>
			<a href="{U_PROFILE}" title="{L_PROFILE}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/profile<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_PROFILE}</a>
	<tr class="row1">
		<td>
			<a href="{U_UM_MCP}" title="{L_MCP}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/moderator<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_MCP}</a>
	<!-- IF U_ACP -->
	<tr class="row1">
		<td>
			<a href="{U_ACP}" title="{L_M_ACP}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/acp<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_M_ACP}</a><br />
	<tr class="row1">
		<td>
			<a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}"><img src="{T_THEME_PATH}/images/portal/user_menue_icons/logout<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->_rtl<!-- ENDIF -->.png" width="16" height="16" alt="" />&nbsp;{L_LOGIN_LOGOUT}</a>
Upload the file after unzip to root/styles/[stylename]/theme/images/portal
user_menue_icons.zip
Update your style:
"Administration Panel" (ACP)> "Styles"> "Templates"> each> "refresh"
"Administration Panel" (ACP)> "Styles"> "Themes"> each> "refresh"
The cache in the "Administration Panel" (ACP) > "General"> "Empty the cache"
[+] Installations Anleitung
Für prosilver basierende Styles
Öffne: root/styles/[stylename]/template/portal/modules/user_menu_side.html
Suche:
             <ul>
                <!-- IF U_ACP -->
Ersetze es mit:
			<ul>
			<ul>
			<ul>
			<ul>
			<ul>
			<ul>
			<ul>
			<ul>
			<ul>
				<!-- IF U_ACP -->
			<ul>
Öffne: root/styles/[stylename]/theme/portal.css
Suche:
       display: block;
       padding: 2px 0;
       font-weight: bold;
       font-size: 90%;
Danach einfügen:
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
	display: block;
	font-weight: bold;
	font-size: 90%;
Für subsilver2 basierende Styles
Suche:
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <!-- IF U_MCP -->
       <tr class="row1">
          <td>
       <!-- IF U_ACP -->
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
Ersetze es mit:
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
       <!-- IF U_ACP -->
       <tr class="row1">
          <td>
       <tr class="row1">
          <td>
Lade den Ordner nach dem entpacken in root/styles/[stylename]/theme/images/portal
Aktualisiere deine Styles:
Hier noch ein paar Screenshots / Here are some screenshots
Prosilver
Davor / before:
Danach / after:
Subsilver2
Davor / before:
Danach / after:
Roger123
phpBB.de User: Roger123
phpBB.com User: Roger123
Re: [Release] Portal Listenpunkte im Benutzer-Menü austausch
Post by Roger123 »
THX für die anleitung klappte suppi
mfg
http://rh-welt.net/
CHUCKY
Post by CHUCKY »
hmm was mache ich falsch?habe alles so gemacht wie es dort steht aber is alles noch beim alten -.-!hat sich nichts gändert!
Hast du auch deinen Template und Themen Cache geleert?
CHUCKY
Post by CHUCKY »
wow das war doch so einfach :roll: danke für die fixe info!jetzt hat es gefunzt!
Wutzmann
phpBB.de User: Wutzmann
phpBB.com User: Wutzmann
Post by Wutzmann »
unter prosilver sind die Änderungen zu sehen aber unter prosilver_se hat sich nichts getan!
Ich habe die den Ordner mit den Bildern nach root/styles/prosilver_se/theme/images/portal kopiert, den Cache geleert und eine Vollständige Style-Aktualisierung durchgeführt!
Ich bin zwar kein Gynäkologe aber ich schau´s mir gern mal an!
Hast du bei prosilver_se auch die Einträge in der portal.css gemacht?
Wutzmann
Post by Wutzmann »
Ich habe einfach ALLE Files vom Portal auch in das prosilver_se Verzeichnis kopiert und... geht :)
Da der Style prosilver_se sich die meisten templates von prosilver holt, müsstest du nur die Bilder in´s
richtige Verzeichniss tun (was du ja getan hast) und die Einträge in die portal.css machen.
Wutzmann
Post by Wutzmann »
Hab's dann nochmal RICHTIG gemacht und siehe da es geht :)
Z-MANN
phpBB.de User: Z-MANN
Post by Z-MANN »
Klasse, funktioniert Perfekt!
Vielen Dank dafür!
Z-MANN
Post by Z-MANN »
Habe mir noch in der "user_menu_side.html" den Listenpunkt "Support Toolkit" unter "Administrations-Bereich" hinzugefügt.
Ich verwende bei "Support Toolkit" das selbe Icon wie beim "Administrations-Bereich", da dies im Prinzip auch zum Adminbereich gehört.
         <ul>
            <!-- IF U_STK -->
               <li><a href="{U_STK}">{L_STK}</a></li>
Funktioniert prima!
Nur diesen Code in die user_menu_side.html einzugeben reicht nicht aus.
  • Es fehlt die Übersetzung der Sprachvariable ({L_STK})
  • Es fehlt die Definition für den Link zum STK (U_STK)
Das hier müsste man zusätzlich machen:
Öffne: root/portal/modules/portal_user_menu.php
Finde:
'U_SELF_POSTS'			=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=egosearch'),
Danach einfügen:
'U_STK'				=> ($auth->acl_get('a_') || $auth->acl_getf_global('a_')) ? append_sid("{$phpbb_root_path}stk/index.$phpEx") : '',
Öffne: root/language/[deine Sprache]/mods/portal/portal_user_menu_module.php
Finde:
'USER_MENU'					=> 'Benutzer-Menü',
Danach einfügen:
'STK'	                    => 'Support Toolkit',
