Hi All,
Great bit of modding from you guys, I just have one question for now.. is there anyway on displaying a custom module within the forum? I still would like the left side of the modules to display while people browse the forum.
Thanks in advanced.
Having portal modules on forum
kalato
Re: Having portal modules on forum
This is currently not possible. Please search "Portalview" for more info on this.
romeo_piter
Hallo.
Sorry for my English
I have such a structure:
Forum is on subdomen (site.forum.ru)
The domen (site.ru) is not used (empty).
I want the portal to be installed to site.ru
Russian support keeps silence on that question.
How can I do that correctly?
Thanks.
Thanks.
You must install the portal at the link below which they have installed the forum.romeo_piter wrote:Hallo.
Thanks.
romeo_piter
So, the portal must be installed to www.site.forum.ru
But how can I make the portal to be on www.site.ru?
If that's a different domain you would probably have to make sure you're even able to connect to the same database on different domains. You'd probably need a phpBB installation on both domains for that to work, or at least the basic set of files on the front page.
