I am using Prosilver Special Edition.
I installed Board3 Portal and love it.
However, Board# Portal doesn't seem to work well with Prosilver Special Edition.
How can I fix it?
The site is www.cyprus-forum.net
Board 3 Portal
- phpBB.com User: Cypriotmatrix
Re: Board 3 Portal
You must also copy the portal directory with the images in the images directory in style.Cypriotmatrix wrote:Hi,
How can I fix it?
The site is http://www.cyprus-forum.net
Re: Board 3 Portal
Thanks guys.archivar wrote:You must also copy the portal directory with the images in the images directory in style.Cypriotmatrix wrote:Hi,
How can I fix it?
Does this solve the Clock issue as it too is not visible?
Re: Board 3 Portal
Yep I did what you said and it worked so thanks a lot.archivar wrote:You must also copy the portal directory with the images in the images directory in style.Cypriotmatrix wrote:Hi,
How can I fix it?
Re: Board 3 Portal
You must also copy portal.css in root / styles / prosilver se / theme /!Kirk wrote:Hi
In your style lacks portal.css!
Controlling again the installation
Re: Board 3 Portal
Well everything seems to be working fine.archivar wrote:You must also copy portal.css in root / styles / prosilver se / theme /!Kirk wrote:Hi
Do I need to do this as well? What will it achieve?
Re: Board 3 Portal
If they did, they will see the difference.Cypriotmatrix wrote:Well everything seems to be working fine.archivar wrote:You must also copy portal.css in root / styles / prosilver se / theme /!Kirk wrote:Hi
