Your phpBB Version: 2.0.
Hi..
I'm trying to install the portal_mod from this site RC2.
But the first file I'm being told to edit is ".htaccess"
but I cant find that file on my server...
Can anyone help ??
Editing .htaccess
- Tester
- phpBB.de User: Heinze 1906
Re: Editing .htaccess
Hello
The .htaccess is a hidden file, so you must set up your FTP Client to show hidden Files.
Alternativ, you can create a new file with the name .htaccess and load it up to your root folder
Or last, take this an name it .htaccess.
MfG
Heinrich
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
MfG
Heinrich
