ajak shoutbox by handyman on portal
Your phpBB Version: 3.02
how can i integrate ajak shoutbox by handyman on portal, i can't fine the english support .
plz help
plz help
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: ajak shoutbox by handyman on portal
Hi Drankur,
the following is an instruction to integrate the Ajax Shoutbox by Paul into the Board3 Portal.
To integrate handymans box it sholud be about the same ...
Open \root\portal.php
Open root\styles\prosilver\template\portal\portal_body.html
create a file "shout_body.html" and save it in \styles\prosilver\template:
Should work like this or at least similar to this ...
// Start session management
$user->session_begin();
$auth->acl($user->data);
//shoutbox
if (!function_exists('as_display'))
include($phpbb_root_path . 'includes/functions_shoutbox.' . $phpEx);
as_display();
//end shoutbox
<!-- IF S_DISPLAY_NEWS -->
<!-- IF S_NEWS_COMPACT -->
<!-- INCLUDE shout_body.html -->
<!-- IF S_CAN_VIEW_AS -->
<div class="forabg">
<div class="inner">
<ul class="topiclist">
<li class="header">
<dl>
<dt>{L_SHOUTBOX}</dt>
</dl>
</li>
<span id="shoutbox"></span>
//<![CDATA[
display_shoutbox = true;
load_shout();
</script>
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
what about handyman shotbox?
handyman do not have this "includes/functions_shoutbox."
Hi sagaraptor,
so what does Handymans Mod have instead?
Thomas
Thomas
handyman's has shout.php. Here is the code:
* @package phpBB3
* @version $Id: shout.php 52 2007-11-04 05:56:17Z Handyman $
* @copyright (c) 2006 StarTrekGuide Group
* @ignore
if (!defined('IN_PHPBB'))
exit;
define('CHAT_TABLE', $table_prefix . 'chat');
define('CHAT_SESSIONS_TABLE', $table_prefix . 'chat_sessions');
/* EDIT these for custom online settings */
$session_time = 300;
$default_delay = 15;
//set status
$times = array(
'online' => 0,
'idle' => 300,
'offline' => 1800,
//set delay for each status
$delay = array(
'online' => 5,
'idle' => 60,
'offline' => 300,
/* DO NOT EDIT ANYTHING BELOW THIS LINE */
$user->add_lang('chat');
$mode = request_var('mode', '');
$last_id = request_var('last_id', 0);
$last_post = request_var('last_post', 0);
$last_time = request_var('last_time', 0);
$get = $init = false;
$count = 0;
switch ($mode)
default:
$sql = 'SELECT * FROM ' . CHAT_TABLE . ' ORDER BY message_id DESC';
$result = $db->sql_query_limit($sql, 25);
$rows = $db->sql_fetchrowset($result);
foreach ($rows as $row)
if ($count++ == 0)
$last_id = $row['message_id'];
$template->assign_block_vars('chatrow', array(
'MESSAGE_ID' => $row['message_id'],
'USERNAME_FULL' => get_username_string('full', $row['user_id'], $row['username'], $row['user_colour'], $user->lang['GUEST']),
'MESSAGE' => generate_text_for_display($row['message'], $row['bbcode_uid'], $row['bbcode_bitfield'], $row['bbcode_options']),
'TIME' => $user->format_date($row['time']),
'CLASS' => ($row['message_id'] % 2) ? 1 : 2,
$db->sql_freeresult($result);
if ($user->data['user_type'] == USER_FOUNDER || $user->data['user_type'] == USER_NORMAL)
$sql = 'SELECT * FROM ' . CHAT_SESSIONS_TABLE . " WHERE user_id = {$user->data['user_id']}";
if ($row['user_id'] != $user->data['user_id'])
$sql_ary = array(
'user_id' => $user->data['user_id'],
'username' => $user->data['username'],
'user_colour' => $user->data['user_colour'],
'user_login' => time(),
'user_lastupdate' => time(),
$sql = 'INSERT INTO ' . CHAT_SESSIONS_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary);
$sql_ary = array(
$sql = 'UPDATE ' . CHAT_SESSIONS_TABLE . ' SET ' . $db->sql_build_array('UPDATE', $sql_ary) . " WHERE user_id = {$user->data['user_id']}";
whois_online();
$template->assign_vars(array(
'TIME' => time(),
break;
$mode = strtoupper($mode);
'FILENAME' => append_sid("{$phpbb_root_path}chat.$phpEx"),
'LAST_ID' => $last_id,
'S_' . $mode => true,
function whois_online()
global $db, $template, $user;
global $delay, $last_post, $session_time;
$check_time = time() - $session_time;
$sql_ary = array(
$sql = 'DELETE FROM ' . CHAT_SESSIONS_TABLE . " WHERE user_lastupdate < $check_time";
$status_time = false;
$sql = 'SELECT *
WHERE user_lastupdate > $check_time
ORDER BY username ASC";
$status_time = time();
if ($row['user_id'] == $user->data['user_id'])
$last_post = $row['user_lastpost'];
$login_time = $row['user_login'];
$status_time = ($last_post > $login_time) ? $last_post : $login_time;
$status = get_status($row['user_lastpost']);
$template->assign_block_vars('whoisrow', array(
'USER_STATUS' => $status,
$user_ary[] = $row['user_id'];
'DELAY' => ($status_time) ? $delay[get_status($status_time)] : $delay['idle'],
'LAST_TIME' => time(),
'S_WHOISONLINE' => true,
return false;
function get_status($last)
global $times;
$status = 'online';
if ($last < (time() - $times['offline']))
$status = 'offline';
else if ($last < (time() - $times['idle']))
$status = 'idle';
return $status;
Far be it from me to ask you to start fresh, but would it be possible to look over the handyman's files and see (if nothing else) would it be possible to just use a Custom Box html to include the Ajax box?
the handyman's mod includes a chat_body.html file..its easy to implement in any page u wosh
just type :
<!-- INCLUDE chat_body.html -->
and ur good to go, ps. this is my first post on this forum.. i use Board3 on my forum here : http://ppcwarez2.com
just type :
Ather,ather wrote:the handyman's mod includes a chat_body.html file..its easy to implement in any page u wosh
just type :
I tried this on my board at http://redmoonlarp.com and it didn't work. I put the INCLUDE in the HTML custom box on the front portal to no effect. Is there somewhere specific in the portal.php file I should be putting this, instead of in a custom block?
erm u cant just put the include... , it has to be in the template file
open the portal.php and add some where the include line
try this, create a new bbcode (visible only to you, with the iframe of chatbox, a=since u can put bbcodes in the POrtal, just put the bbcode u made, see if that works
ok see this : http://ppcwarez2.com/phpbb/portal.php , that s my forum.. as u can see its appearing above now, but it can be chaged if u play with it a little, goto ACP/Styles/Templates/<click your temple>/and press edit, select the portal_body.html from the list and add <include.....>, purge cache and ur done
I did exactly that:ather wrote:ok see this : http://ppcwarez2.com/phpbb/portal.php , that s my forum.. as u can see its appearing above now, but it can be chaged if u play with it a little, goto ACP/Styles/Templates/<click your temple>/and press edit, select the portal_body.html from the list and add <include.....>, purge cache and ur done
<!-- IF S_DISPLAY_WELCOME -->
<!-- IF S_DISPLAY_WELCOME_GUEST and S_USER_LOGGED_IN -->
<!-- INCLUDE portal/block/welcome.html -->
<!-- IF S_CUSTOM_CENTER -->
<!-- INCLUDE portal/block/custom_center.html -->
<!-- IF S_DISPLAY_RECENT -->
<!-- INCLUDE portal/block/recent.html -->
Done, with the exact same result. Only this time it's above the custom center block. I've moved it to a few different points on the portal_body.html, all with the exact same effect.ather wrote:move theafter,Code: Select all
Again, http://redmoonlarp.com for what it looks like. chat_body.html appears to not be making all the calls that it needs to.
move the
after,
