I did not see this in the FAQ though I am sure this must of been asked before I didnt find this question in the search...
When I first installed the board3 portal mod in Prosilver there is a portal and board index link in the nav bar below the header. I am now using a subsilver2 based template for my site when I switched templates to the subsilver2 based the portal link has disappeared from the nav bar, I only see the board index link. How do I go about creating the portal link in the navbar, thank you!
Create link to portal in nav bar
Re: Create link to portal in nav bar
In the board3 zip file under templates there is a subsilver2.xml file, follow the edits in there.
