SQL Error
SmauG
SQL Error
Post by SmauG »
When i try to install portal, just after click submit (install v1.0.0RC1) i got this error:
Error General
SQL ERROR [ mssql ]
El nombre de columna 'phpbb_portal_config' no es v?lido.
Invalid column name '%.*ls'. [207]
SQL
if exists (select * from sysobjects where name = phpbb_portal_config) drop table phpbb_portal_config
BACKTRACE
FILE: includes/db/mssql.php
LINE: 137
CALL: dbal->sql_error()
FILE: install_portal/install.php
LINE: 258
CALL: dbal_mssql->sql_query()
Heinrich-XIV
Tester
phpBB.de User: Heinze 1906
phpBB.com User: Heinrich-XIV
Re: SQL Error
Post by Heinrich-XIV »
Hello
Have you made all the edits from the Portal install.xml?
You purged the cache after this?
It's a Problem with the constants.php file, I think.
Check all your files that you have edit of Errors or undo changes.
Greets
Heinrich
SmauG
Re: SQL Error
Post by SmauG »
Yes, i edited all files two times, and i also purged the cache, but error remains :(
I'm using mssql 2000, could be the problem?
Any ideas?
EDIT:
I've made a fresh forum install, with no changes, i only edited portal required files and uploaded portal files.
If i go to forum's root, i got this error:
General Error
SQL ERROR [ mssql ]
El nombre de objeto 'phpbb_portal_config' no es v?lido.
Invalid object name '%.*ls'. [208]
I had this error last time, but i made that db manually.
This time i'll wait for an answer :)
Greetz
Heinrich-XIV
Tester
Re: SQL Error
It could be, indeed.
Why don't you post this in your first Message? We can't give you the right Support without the required Information, so we can only give you an Answer of known Standard Problems, wich somtimes happens. :roll:
I think, Kevin knows more about this, so wait for his Answer.
@Kevin: What do you think about of a intregation from the "Support Ticket System" Mod by nickvergessen here? It is very difficult to give Support without any sorely needed Information. :(
Greets
Heinrich
Re: SQL Error
yes - it has something to do with MSSQL - as we have a lag of testing environments we don't have much experience with it.
Please try the following:
open root\install_portal\install.php
search (around line 255):
					case 'mssql':
						$sql = 'if exists (select * from sysobjects where name = ' . $table_prefix . 'portal_config)
						drop table ' . $table_prefix . 'portal_config';
						$db->sql_freeresult($result);
					break;
replace with:
					case 'mssql':
						$sql = 'if exists (select * from sysobjects where name = ' . $table_prefix . 'portal_config')
					break;
Save and upload
if the code above does not work, please try the following instead:
					case 'mssql':
						$sql = 'IF EXISTS(SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_NAME =  ' . $table_prefix . 'portal_config)
					break;
Heinrich-XIV wrote:@Kevin: What do you think about of a intregation from the "Support Ticket System" Mod by nickvergessen here?
Yes, we can think about it.
SmauG
Re: SQL Error
Post by SmauG »
I tried both codes, but error remains :(
If it helps, this line
means
The name of the object 'phpbb_portal_config' is not valid
@Heinrich: I forgot to tell that i'm using mssql because i didn't thought that it could be a problem.
Re: SQL Error
Okay - as a quick fix - please try this:
find:
                   case 'mssql':
                   break;
replace with:
                   case 'mssql':
                   break;
It's just for removing the portal table, if it's present from a installation before. As you don't have it installed before, the installer should work without this code.
SmauG
Re: SQL Error
Post by SmauG »
I know, i already tried this, but the error remains :S
I searched on all install.php (portal_install) and the line with this error doesn't exist (because i deleted it as you said), i deleted cache, i tried from another PC, and nothing, the error still happens, i think this have no sense.
Any ideas?
Re: SQL Error
Please post the complete error message, like you did in the first post.
SmauG
Re: SQL Error
Post by SmauG »
Is the same error, here's the code
SQL ERROR [ mssql ]
SQL
BACKTRACE
LINE: 137
LINE: 258
I also searched on
  • includes/db/mssql.php
  • install_portal/install.php
the lines with the error (dbal->sql_error() and dbal_mssql->sql_query() ) and nothing, doesn't exit.
I'm so lost at this moment.
Re: SQL Error
Looks definately to me like you haven't purged your (board - not browser!) cache after the changes - or forgot to upload the modified install.php
In this case please try from the beginning.
SmauG
Re: SQL Error
Post by SmauG »
First time i forgot to prune forum cache, but second time, when i installed a fresh forum, i did all ok.
I modified directly host archive. (I checked it three times, it's modified)
Re: SQL Error
If you have done this changes:
Kevin wrote:Okay - as a quick fix - please try this:
find:
                   case 'mssql':
                   break;
replace with:
                   case 'mssql':
                   break;
then it's impossible that you get this error message:
    SQL ERROR [ mssql ]
    SQL
    BACKTRACE
    LINE: 137
    LINE: 258
This error message comes definitely from the unmodified install.php
So there is something going wrong.
Have you tried downloading the install.php file and double checked that your changes are included then?
If you don't get further i could offer you to take a direct look on your forum - PM me the login data (FTP and Admin Account) i need.
SmauG
Re: SQL Error
Post by SmauG »
Forget it, magically now runs ok :shock:
Thanks for the help ^^
