[EN] How to ... Redirect to the portal after login / logout
open ucp.php
search:
    case 'login':
        if ($user->data['is_registered'])
            redirect(append_sid("{$phpbb_root_path}index.$phpEx"));
        login_box(request_var('redirect', "index.$phpEx"));
    break;
replace with:
    case 'login':
            redirect(append_sid("{$phpbb_root_path}portal.$phpEx"));
        login_box(request_var('redirect', "portal.$phpEx"));
    break;
Redirect to the portal after logout
search:
    case 'logout':
        if ($user->data['user_id'] != ANONYMOUS && isset($_GET['sid']) && !is_array($_GET['sid']) && $_GET['sid'] === $user->session_id)
            $user->session_kill();
            $user->session_begin();
            $message = $user->lang['LOGOUT_REDIRECT'];
            $message = ($user->data['user_id'] == ANONYMOUS) ? $user->lang['LOGOUT_REDIRECT'] : $user->lang['LOGOUT_FAILED'];
        meta_refresh(3, append_sid("{$phpbb_root_path}index.$phpEx"));
        $message = $message . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}index.$phpEx") . '">', '</a> ');
        trigger_error($message);
    break;
replace with:
    case 'logout':
        meta_refresh(3, append_sid("{$phpbb_root_path}portal.$phpEx"));
        $message = $message . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}portal.$phpEx") . '">', '</a> ');
    break;
Change text "Return to the index page" to "Return to the portal page"
open root\language\en\common.php
search:
'RETURN_INDEX'				=> '%sReturn to the index page%s',
replace with:
'RETURN_INDEX'				=> '%sReturn to the portal page%s',
Return to “KB-Archiv”
