[Release] Add Online-Status to Team for B3P2.0.0
This will add the online status to the team block.
Durch diese Anleitung wird der Online Status im Team-Block angezeigt.
Version: 1.0.1
Tested with Board3 Portal 2.0.0
Getestet mit Board3 Portal 2.0.0
Normal Team block / Normaler Team Block
Instructions for normal team block:
[+] Install Instructions
Open: root/portal/modules/portal_leaders.php
Find:
    if ($row['group_type'] == GROUP_HIDDEN && !$auth->acl_gets('a_group', 'a_groupadd', 'a_groupdel') && $row['ug_user_id'] != $user->data['user_id'])
        $group_name = $user->lang['GROUP_UNDISCLOSED'];
        $u_group = '';
        $group_name = ($row['group_type'] == GROUP_SPECIAL) ? $user->lang['G_' . $row['group_name']] : $row['group_name'];
        $u_group = append_sid("{$phpbb_root_path}memberlist.$phpEx", 'mode=group&g=' . $row['group_id']);
After add:
    // Generate online information for user
    $sql = 'SELECT session_user_id, MAX(session_time) as online_time, MIN(session_viewonline) AS viewonline
        FROM ' . SESSIONS_TABLE . '
        WHERE ' . $db->sql_in_set('session_user_id', $row['user_id']) . '
        GROUP BY session_user_id';
    $result2 = $db->sql_query($sql);
    $update_time = $config['load_online_time'] * 60;
    $user_online = false;
    while ($row2 = $db->sql_fetchrow($result2))
        $user_online = (time() - $update_time < $row2['online_time'] && (($row2['viewonline']) || $auth->acl_get('u_viewonline'))) ? true : false;
    $db->sql_freeresult($result2);
Find:
        'USER_ID'            => $row['user_id'],
After add:
        'USER_ONLINE'        => $user_online,
Open: root/styles/prosilver/template/portal/modules/leaders_side.html
Find:
      <span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{admin.USERNAME_FULL}</strong></span><br style="clear:both" />
Replace with:
      <span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{admin.USERNAME_FULL}</strong></span><!-- IF admin.USER_ONLINE eq 'true' --><img src="{T_THEME_PATH}/images/portal/green_on_16.png " width="16" height="16" alt="{L_ONLINE}" style="float: right;" /><!-- ELSE --><img src="{T_THEME_PATH}/images/portal/red_on_16.png " width="16" height="16" alt="{L_OFFLINE}" style="float: right;" /><!-- ENDIF --><br style="clear:both" />
Find:
      <span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{mod.USERNAME_FULL}</strong></span><br style="clear:both" />
Replace with:
      <span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{mod.USERNAME_FULL}</strong></span><!-- IF mod.USER_ONLINE eq 'true' --><img src="{T_THEME_PATH}/images/portal/green_on_16.png " width="16" height="16" alt="{L_ONLINE}" style="float: right;" /><!-- ELSE --><img src="{T_THEME_PATH}/images/portal/red_on_16.png " width="16" height="16" alt="{L_OFFLINE}" style="float: right;" /><!-- ENDIF --><br style="clear:both" />
Upload the following 2 files to root/styles/prosilver/theme/images/portal
Anleitung für normalen Team Block:
[+] Installations Anleitung
Öffne: root/portal/modules/portal_leaders.php
Finde:
        $u_group = '';
Danach einfügen:
Finde:
Danach einfügen:
Öffne: root/styles/prosilver/template/portal/modules/leaders_side.html
Finde:
Ersetzen mit:
Finde:
Ersetzen mit:
Lade diese 2 Bilder in root/styles/prosilver/theme/images/portal hoch.
Extended Team block / Erweiterter Team Block
Instructions for extended team block:
Open root/portal/modules/leaders.php
Find:
        $groups[$row['group_id']]['group_users'][] = array(
            'user_id'        => $row['user_id'],
            'username'        => $row['username'],
            'user_colour'    => $row['user_colour'],
Before add:
Find:
After add:
            'user_online'    => $user_online,
Find:
                    'USER_ID'            => $group_user['user_id'],
After add:
                    'USER_ONLINE'        => $group_user['user_online'],
Open: root/styles/prosilver/template/portal/modules/leaders_ext_side.html
Find:
		<span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{group.member.USERNAME_FULL}</strong></span><br style="clear:both" />
Replace with:
      <span style="float:<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->float:right; padding-right:5px;<!-- ELSE -->float:left; padding-left:5px;<!-- ENDIF --> padding-top:2px;"><strong>{group.member.USERNAME_FULL}</strong></span><!-- IF group.member.USER_ONLINE eq 'true' --><img src="{T_THEME_PATH}/images/portal/green_on_16.png " width="16" height="16" alt="{L_ONLINE}" style="float: right;" /><!-- ELSE --><img src="{T_THEME_PATH}/images/portal/red_on_16.png " width="16" height="16" alt="{L_OFFLINE}" style="float: right;" /><!-- ENDIF --><br style="clear:both" />
Upload the following 2 files to root/styles/prosilver/theme/images/portal (if the do not already exist)
Anleitung für Erweiterten Team-Block:
Finde:
Davor einfügen:
Finde:
Danach einfügen:
Finde:
Danach einfügen:
Öffne: root/styles/prosilver/template/portal/modules/leaders_ext_side.html
Finde:
Ersetzen mit:
Lade diese 2 Bilder in root/styles/prosilver/theme/images/portal hoch.(falls nicht schon vorhanden)
Shorty1968
Portal Enthusiast
Re: [Release] Add Online-Status to Team for B3P2.0.0
Post by Shorty1968 »
Hallo ich habe die änderungen gemacht und die Grafiken sind auch im richtigen ordner Trozdem wird sie nicht angezeigt,woran kann das liegen?
Grafiken liegen im Ordner styles/prosilver/theme/images/portal
Board und Browser Cache sind geleert.
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
Moin,
sicherlich müssen die Grafiken auch noch in den von Dir verwendeten Style.
Was sagt ein Rechtsklick auf die fehlende Grafik?
CPG
Shorty1968
Portal Enthusiast
hi das wusste ich und sind sie auch,ein rechtsklick sagt das die Datein da sind wo sie sein sollen. ;)
cpg
Sponsor
phpBB.de User: cpg
Post by cpg »
Moin,
na, dann müsste es auch funktionieren.
Meine Grafiken sind in
http://www.mein-forum.de/phpBB3/styles/ ... -on-16.png
... und es klappt tadellos.
CPG
Shorty1968
Portal Enthusiast
Ah jetzt habe ich es vielen dank,das Problem war das wenn man hier die Grafiken speichert laten sie red_on_16.png im Template Codes heisen sie aber red-on-16.png,der unterschied ist das _ anstelle von dem -,aber denoch vielen dank eventuell wäre es mir ohne dich nie aufgefallen. ;)
Da hatte ich einen Schreibfehler drin hab ihn berichtigt.
Danke für den Hinweis Shorty :)
Heinrich-XIV
Tester
phpBB.de User: Heinze 1906
phpBB.com User: Heinrich-XIV
Post by Heinrich-XIV »
Schöne Sache. :)
Falls ich mal irgendwann wieder Lust dazu bekomme, ein Forum online zu stellen, werde ich das auf jeden Fall mit einbauen.
Heinrich
