yesterday I upgraded my forum from 3.0.10 to 3.0.11 and from Portal 2 beta to 2.0
I was checking if all was ok, but i found a very strange thing...
In the "who si online" page all users,bot,search engine, got the same IP address...
The IP address is from the server that host my forum...
Before the upgrade was all ok.
I tried to reset all the sessions,cache, etc, but nothing changed...
There is something I can do ?
after update to portal 2.0, IP problems with "who is online"
Re: after update to portal 2.0, IP problems with "who is onl
I do not think the portal is to blame for their problems.
Imagine the state before its update restores.
Do not update all at once!
Wait a week after each subsequent update.
So they can see better when the error occurs.
Fortunatly, I successfully solved the problem...
I think it was the upgrade to 3.0.11...
Infact I changed some things inside the startup.php and all works fine now!
The portal is great and now is more faster!
