I want to skip the install/index.php
Is there a workaround?
For example I want the sql execute in phpmyadmin.
Thanks in advance.
sql / install failed
no1san
- phpBB.com User: no1san
no1san
Re: sql / install failed
Why is Table 'xx.xx_portal_modules not created?
(uninstal and install did not help.)
Doing search now for this table
Board3 Portal
PHP Version: 5.2.6-1+lenny13
DBMS: MySQL(i) 5.0.51a-24+lenny5-log
phpBB3 Version: 3.0.10
Adding basic set of modules
SQL ERROR Table 'xx.xx_portal_modules' doesn't exist
Board3 Portal
no1san
Sqwirtle
Any one have a solution.
I have the same exact error after trying to upgrade.
Table 'db352413841.phpbb_portal_modules' doesn't exist [1146]
I then tried to uninstall and re-install with to luck.
The installer has been cleaned up in the next version of the portal so this might also solve the issues you are having. I can't tell you when it'll be released yet as it's being validated right now.
