I want to use the proglassed red style for my board
http://www.phpbb.com/customise/db/style ... sred/demo/
I have installed the style but it doesn't seem to work with board 3 portal.
Is there a simple way i can make it work? if yes could you provide some direction please
regards
How to use other styles?
Re: How to use other styles?
Thread moved from Board3 Portal 2.0.x - English Support on board3 Styles <Released styles' style requestsfive2eight wrote:I want to use the proglassed red style for my board
regards
I look at the style and I'll do what I can.
EDIT:
proGlass / proGlass_Red - not wide enough for Board3 Portal
Can we not overcome this by adjusting the width to 980?archivar wrote:
EDIT:
If not how could I change the default prosilver style from blue to red?
I've adapted the most sought-after style here: viewtopic.php?f=39&t=5320
Maybe they like the style "Milky Way RED"? viewtopic.php?f=57&t=5332
We do not provide support for color matching on the Style!
Thanks for your efforts archivar
could you take a look at http://www.phpbb.com/customise/db/style/reds/demo/ and advise if this could be made compatible
regards
regards
You should use only styles that are based on current php version!five2eight wrote:Thanks for your efforts archivar
regards
This is not based on current Style phpBB version (s) 3.0.10.
ok
I am starting to understand, please excuse my ignorance.
I have installed the one you suggested earlier "Milky Way RED"? viewtopic.php?f=57&t=5332
How do i get it to work with board 3?
Click in the manual "[+] English".archivar wrote: Maybe they like the style "Milky Way RED"? viewtopic.php?f=57&t=5332
To open, they must accept scripts in the browser.
Sorry, what do you mean? what manual?
I have installed Milky Way Red, this works fine with PHPBB3, However how do i get it to work with the Board 3 portal?
If you could post a link to some instructions that would be most helpful
regards
The thread you linked to already has step-by-step instructions.
Sorry should have read the whole post
Installed and made all the changes, everything seems to work fine except one issue.
The titles on the modules seems to be 3 or pixals too high on each module
I have refreshed everything in the styles admin
any ideas?
regards
any ideas?
regards
Please use the Forum "Styles Support" on matters of style.five2eight wrote:......
any ideas?
regards
